BEST BOV?
Best on a stock turbo? Factory surge valve. Want aftermarket or adding an upgraded turbo? HKS SSQV, Greddy Type RS, Turbosmart lineup and a few other's come to mind. Tial was suggested but I highly recommend not using it with very few mods. Especially if used with a stronger spring. Many Tial's come with a 9psi spring which normally blow's off at around 15-17psi. Not the best for a small turbo.
i personally think if u want your warranty..get the mopar conversion...but...if u want more boost but want to use the original...id play arouond with the spring inside..and u can put a new spring in it and set it to the max boost u can use witht he stock afratio...if that makes any sense..but you need to know what your doing..you could seriously damage your car...
