please list probs wit 05srt4
Old Aug 25, 2006 | 08:58 PM
noplayen05srt's Avatar
noplayen05srt
Default please list probs wit 05srt4
i have owned my car since febuary 06 it was the last one availible here... last month my car went into the shop for a new motor because the motor mount broke which inturn cracked the block... its still in the shop and i want to know of all things i should have them check out before it is completed... i saw back there was somthing about the tranny with i think it was 3rd gear and somthing with the fly wheel blots... anything else anyone can give me would be great ....
Old Aug 25, 2006 | 09:01 PM
noplayen05srt
Default RE: please list probs wit 05srt4
also anyone know of a good motor mount that will help with wheel hop but also be a little more flex than the stock ones so i dont have to go through this again.... i also am looking to see if i can find a 5 stage dual memory boost controller anyone know of one?
Old Aug 25, 2006 | 09:16 PM
LilSparkPlug's Avatar
LilSparkPlug
The only other mounts available are solid, which cause vibrations. You can get them from a variety of different vendors, it all depends on your decision of which to get.
Don't have them check for problems that aren't there. If they arise in the future, then have it checked out.
Common Problems:
- Flywheel bolts backing out
- 3rd gear (grinding on downshifts, not engaging into gear)
- 4th spark plug wire (plugs and wires in general need to be upgraded...the stock ones can't take the heat)
etc.
But like I said if they aren't occuring, don't fix something that isn't broken.
Old Aug 25, 2006 | 09:21 PM
noplayen05srt
well im in pretty good with my dealership.... my motor shouldn't even be covered by warrenty but my mechanic got it covered for me... so i can have whatever checked out for nothing ... everything done they do i get done with out labor charge so i would rather get it checked just to make sure its all fine still.... i already have 18000 miles on it so yea....
Old Aug 25, 2006 | 09:24 PM
noplayen05srt
kinda like the clutch is shot because of the cap in it shattered..... everyone should get that checked since our cars have dry clutches... the cap shatters easily... every srt around here has had to get a new clutch because of it.... my mechanic actualy got me the mopar performance clutch just so i wouldn't have to worry about it as much... and all im doing is paying cost on it
Old Aug 25, 2006 | 09:25 PM
bigham's Avatar
bigham
05 red with 28000 miles now and knock on the computer screen no problems yet but that is because sparky was taking all of the problems for a while there
Old Aug 26, 2006 | 03:31 AM
LilSparkPlug
Yes I did 63 and change thousand miles on mine, and my clutch and transmission have been good to me so far.
I just don't see the point of fixing something that isn't broken. It isn't even like you're highly modified enough to worry about a voided warranty.
Old Aug 27, 2006 | 12:52 AM
noplayen05srt
no im not yet but about two weeks after i get it back its going back for alot of upgrades...
Old Aug 27, 2006 | 08:18 PM
Wolfish's Avatar
Wolfish
I've got just under 15,000kms(about 9,500 miles) on mine, and the only thing that's gone wrong was the steering column had to be replaced. All under waranty of course. I've had it for a little over a year and a half, so it's so-far-so-good for me.
Old Aug 28, 2006 | 04:20 AM
srt4babe's Avatar
srt4babe
What's wrong with 05's???? Everything!!!!
I have had mine less than a year and so far . . .
Wiring harness completely replaced after car kept imobilizing itself after making right turns
3 new boost gauges
Oxygen sensor busted. . . needing to be fixed AGAIN!!!
Never wanting to go into 3rd gear!!!!
Just to name a few My car is a problem child
