ugh
Old Aug 27, 2006 | 11:49 PM
wordslayer's Avatar
wordslayer
Default ugh
Just as I wrote about how great my car has been doing, I jinxed it. My car has a blow off valve, mopar, and when I now floor it.....hmmmmmm let me try this again.
do you know how, when you have the mopar BOV how it does that Pffffish sound? well,,,,I was driving my car today and when I floor it, I hear the pffffish sound BEFORE I let off the gas. In other words, it is Pfffffishing while I am throttling it. It still Pffffishes when I shift, but it is pfffffishing way too soon.
thoughts on what might be wrong???
Old Aug 27, 2006 | 11:58 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: ugh
Did you use a gasket sealer like Permatex when you put it on?
Dusty
Old Aug 28, 2006 | 12:11 AM
winniep's Avatar
winniep
Default RE: ugh
TPS?
Old Aug 28, 2006 | 12:35 AM
wordslayer's Avatar
wordslayer
Default RE: ugh
ORIGINAL: dustyloins
Dusty
Yes, I followed your advice when I had it installed, and I had them use the permatex something or other.
Old Aug 28, 2006 | 12:37 AM
wordslayer's Avatar
wordslayer
Default RE: ugh
ORIGINAL: winniep
TPS?
I guess it could be the TPS, but the car runs fine, or so it seems, unless you are throttling on it, and it's only then that you get the extended pfffffshing sound. If running it regularly, it sounds like the normal blow off sound.
TPS, huh?
Old Aug 28, 2006 | 01:26 AM
winniep's Avatar
winniep
Default RE: ugh
It sounds like a throttle position sensor problem to me. I was just wondering if you have had your TPS changed out yet? Like 40% of people with an SRT have this problem at some point with some of the symptoms being what you've described. Hope you get it figured out.
Old Aug 28, 2006 | 02:58 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: ugh
Its 100% the TPS wiring that broke loose on you. Theres a TSB on it, take it to the dealer and have them fix it. Very common problem. The wires are too short from the factory and need to be lengthened to prevent them from seperating themselves under engine torque.
Old Aug 28, 2006 | 03:28 AM
PSI Chick's Avatar
PSI Chick
Default RE: ugh
sounds like you might have blown a line
Old Aug 28, 2006 | 04:08 PM
808srt's Avatar
808srt
Default RE: ugh
i had the exact same prob with the bov (i have the turbo xs rfl idk if its the same set up) but i jus had a blown line and jus had to replace the 4 inch piece of hose with the hole and it was good as knew like nothing ever happend
Old Aug 28, 2006 | 09:59 PM
Pressurecooker's Avatar
Pressurecooker
Default RE: ugh
Pffffudge!
