hand brake
Old Sep 7, 2006 | 02:05 AM
jac05srt4's Avatar
jac05srt4
Default hand brake
Is there a way to tighten the Hand Brake? I had it at the dealership today for an oil change and I asked for it to be tightened the service manager told me that it could not be done because there is no way to do it. He also said that it is just the way all neons and srt4s are.
Old Sep 7, 2006 | 04:13 AM
PSI Chick's Avatar
PSI Chick
Default RE: hand brake
there's a adjustment nut by the rear tires
Old Sep 7, 2006 | 04:53 AM
LilSparkPlug's Avatar
LilSparkPlug
Smart guy lmfao....thats why they're drum in hat, just so they're easily accessible and adjustable.
Make sure if your brakes themselves need adjusting, always adjust those before the E-brake cable.
Old Sep 7, 2006 | 02:30 PM
Four Banger Anger's Avatar
Four Banger Anger
are you just adjusting so you yank it up so it holds when you do a massive burnout?
Jordan
Old Sep 7, 2006 | 06:27 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
im beginning to trust this forum much more than the dealership. i dont think the one here has seen an srt4 before
Old Sep 7, 2006 | 07:43 PM
Plan B's Avatar
Plan B
ORIGINAL: flamingpinhead
I hear that!
Old Sep 7, 2006 | 09:35 PM
moparman04's Avatar
moparman04
where is the adjustment nut exactly ??? my ebrake has to be yanked up almost 90 degrees befroe it works
Old Sep 8, 2006 | 04:06 AM
04_T_4's Avatar
04_T_4
Yes yes, do tell!
PSI Chick's Avatar
PSI Chick
if you look behind the rear tires near the back of the caliper there's a star looking adjustment screw there. tighten it until there's resistance on the wheel when you try to turn it, then back it off some.
Old Sep 8, 2006 | 09:08 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Isn't it crazy how almost all of our performance advice either comes from LSP or PSI CHICK? Thats freakin awesome. I am going to tighten mine up today, I have to do a 90 degree jolt on my ebrake as well, it feels so loose its not even funny.
