need help
Old Sep 22, 2006 | 04:52 PM
mpplaya07's Avatar
mpplaya07
Default need help
is it safe to raise the boost to 10 psi wit the stock wastegate.... i got a manual boost controller..
Old Sep 22, 2006 | 05:48 PM
Plan B's Avatar
Plan B
Default RE: need help
Would you have to raise it to reach 10 psi? Stock I am spiking 16, holding 13-14....
Old Sep 23, 2006 | 04:16 AM
mpplaya07's Avatar
mpplaya07
see i peak and hold at 8
Old Sep 23, 2006 | 06:29 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
HOLY BOOST LEAK BATMAN!!!
8psi in all gears??? you gota a leak somewhere bud! inspect, check and double check all of your lines and connections. what modifications do you have? ghetto occ? you should be peaking at 16/17 and then holding around 14psi STOCK (first gear is not quite 14)
Old Sep 24, 2006 | 10:49 PM
mpplaya07's Avatar
mpplaya07
i got a exhaust,dp,intake, and a bov.... my guage never reads at like 20 on the vac side is always between 22-30 liek it varies all the time.... when i gun it in all gears it goes straight to 8 psi and holds.... only like one time did it go up to 10 psi and hold but that was in 5th gear going bout 140mph
Old Sep 24, 2006 | 10:55 PM
flamingpinhead
Section Moderator
at idle you should read a vac of about 20 give or take 1. perhaps your boost gauge is in need of attention? either your gauge is way off or your leaking massive amounts of boost somewhere
Old Sep 24, 2006 | 11:08 PM
05SRTStage3's Avatar
05SRTStage3
Yes you either have a major boost leak or you have a broken boost gauge.....I had to replace mine after only 8k miles
Old Sep 25, 2006 | 01:19 AM
mpplaya07's Avatar
mpplaya07
could it be the hoses from the bov? what size hoses did u guies use for ur bov connection...
Old Sep 25, 2006 | 11:06 PM
flamingpinhead
Section Moderator
explain a little further... are you talking about the little hose on the stock BOV or do you have an aftermarket? most aftermarket have no 'hoses' although i have seen a strange setup in which a T was placed by the intake manifold, on the vac line from the pvc -> intake manifold... off of the T, a line went down under a little ways where a BOV was placed... never seen anything like it before or after
Old Sep 26, 2006 | 07:35 PM
mpplaya07's Avatar
mpplaya07
i got an hks bov... im tlkin bout the vaccume lines
