E-85
Old Oct 7, 2006 | 05:17 PM
rare04's Avatar
rare04
Default E-85
Anyone heard of the E-85 fuel. All I know is that you can get more power, but the car needs to be tuned for it. Any input on this?
Old Oct 7, 2006 | 08:16 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: E-85
E-85 fuel is 85% ethanol and 15% gasoline. It's used in flexable fuel vehicles (FFVs) and Dodge has a few of them, but the Neon/SRT-4 is not one of them.
From the net:
Operating fuel-injected non-FFVs on more than 50% ethanol will generally cause the check engine light (CEL) to illuminate, indicating that the electronic control unit (ECU) can no longer maintain closed-loop control of the internal combustion process due to the presence of more oxygen in E85 than in gasoline. Once the CEL illuminates, adding more ethanol to the fuel tank becomes rather inefficient. For example, running 90% ethanol in a non-FFV will reduce fuel economy by 33% or more relative to what would be achieved running 100% gasoline. Even more importantly, continuing to operate the non-FFV with the check engine light (CEL) illuminated may also cause damage to the catalytic converter as well as to the engine pistons if allowed to persist. To run a non-FFV with amounts of ethanol high enough to cause the CEL to illuminate risks severe damage to the vehicle, that may outweigh any economic benefit of E85.....
Dusty
