hood scoop mod?
Old 10-08-2006, 01:10 AM
moparman04's Avatar
moparman04
moparman04 is offline
Default hood scoop mod?
has anybody tried this yet ?
i guess you cut about 3/4 of an inch off of the back of the scoop insert for better air flow.
heard it drops temps pretty well. any trouble i should worry about in rain and what not
Old 10-08-2006, 01:24 AM
dustyloins's Avatar
dustyloins
dustyloins is offline
Hall of Fame Member
Location: Alamosa, Colorado (200 yards from the Rio Grande)
Default RE: hood scoop mod?
When it gets really, really hot here (like 364 days out of the year) I just pop the hood and let the manual release hold it in place (nobody can really tell unless they get up close to the car) unless I'm going to be doing freeway driving, in which case the engine stays cool without any additional help.
Dusty
Old 10-08-2006, 02:46 AM
flamingpinhead's Avatar
flamingpinhead
flamingpinhead is offline
Section Moderator
Dodge Forum Moderator
ehh, as long as the hood dont hit the windshield.
Old 10-09-2006, 03:32 PM
whatneon's Avatar
whatneon
whatneon is offline
dusty, thats just not right.....
Old 10-09-2006, 06:45 PM
Four Banger Anger's Avatar
Four Banger Anger
Four Banger Anger is offline
yes sir it works, I did it myself, my friend has done it also, no rain gets in either. The scoop is a pita to pop out though, I noticed temp drops alot when cruising, or on the freeway, its simple to do and it works, next I will be doing a 180 stat, coolant flush+water wetter and a new rad cap so everything is staying even cooler.
Old 10-11-2006, 05:42 AM
moparman04's Avatar
moparman04
WOW!!! it works like a champ !!!!!!
Old 10-11-2006, 02:52 PM
WiLLisILL's Avatar
WiLLisILL
WiLLisILL is offline
if u didn't want to cut u could drill some holes that should work as well
Old 10-11-2006, 03:41 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
xXxIZZYxXx is offline
Travis does the mod work? If so.... you mind helping a brother out?
Old 10-11-2006, 03:44 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
YeahItsAHemi345 is offline
Does anybody have pic's? [&:]
Old 10-12-2006, 03:10 AM
moparman04's Avatar
moparman04
ill post them tomorrow when its lighter out side
Quick Reply: hood scoop mod?
