which upgrade
Old Oct 10, 2006 | 09:55 PM
phoshiz's Avatar
phoshiz
Default which upgrade
hey im thinking on getting a srt-4
I dont know much about cars at all and I was just wondering what would be the best thing i should upgrade first with the srt-4. I will have around 1000 dollars. I was thinking about getting a stage 1. Anything else? thanks
Old Oct 10, 2006 | 10:24 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: which upgrade
Stage 1, CAI and the Mopar/Borla exhaust.....that might leave you enough for a Mopar BOV as well......
Dusty
Old Oct 12, 2006 | 03:51 AM
PSI Chick's Avatar
PSI Chick
stage 1, motor mounts, wga, mbc. if you have anything left get a used exhaust.
Old Oct 12, 2006 | 08:38 AM
talisman's Avatar
talisman
Old Oct 12, 2006 | 11:43 AM
PSI Chick's Avatar
PSI Chick
cai's are worthless other than for opening up room in the engine bay.
Old Oct 12, 2006 | 02:00 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Wouldn't a down pipe be more useful than a cat-back?
Old Oct 12, 2006 | 02:16 PM
PSI Chick's Avatar
PSI Chick
no. if not going with a full 3" turbo back a cat back should be first on the list. if you get a dp, then you're going from 2.25" to 3" back down to 2.25" which does you no good at all. a 3" tbe is really the way to go though, no use wasting money on a cat back imo/e.
Old Oct 12, 2006 | 03:27 PM
whatneon's Avatar
whatneon
If I had an extra grand I would throw it towards the principal on my loan...if its paid for thats cool. Im just a firm believer in having no loans on "toys" and when the mods start, that is exactly what the car will become. Start modding engine and then it needs a clutch, add the HD clutch, break a halfshaft, fix the halfshaft and lunch a tranny, and so on. Once you go that route it cant be your only means of transportation because parts are no longer available at the dealers or auto parts and you are at the mercy of mail order.
Old Oct 12, 2006 | 03:32 PM
PSI Chick's Avatar
PSI Chick
if you brake a half shaft because of a clutch you have bigger problems than worrying about a loan. you seriously need a driver mod.
Old Oct 12, 2006 | 04:02 PM
whatneon's Avatar
whatneon
just throwing out an example on how mods snowball....how long were you down with the trans?
