Keyless entry reprogramming
Old Nov 1, 2006 | 09:51 PM
Zravis's Avatar
Zravis
Default Keyless entry reprogramming
Does anyone know if it's possible to program a new remote without having an original to enter programming mode? Or is this a dealer only rape job?
Old Nov 1, 2006 | 10:14 PM
Burnnout's Avatar
Burnnout
Default RE: Keyless entry reprogramming
Not sure if dodge is the same as nissan... but nissan's you can program the remotes yourself but need a Nissan scan tool to program keys... the procedure for a remote is... shut the door, hit the lock button on the door, put key in and out of ignition until the dash lights flash, put key in, turn to acc, hit the lock button on the remote, open the door, shut the door and hit the lock button on the remote again..... like I said not sure if it's the same but it's worth a shot until someone else posts
