oil leak
Old Nov 2, 2006 | 08:21 AM
joshgish's Avatar
joshgish
Default oil leak
Hey everyone. I just got my black 04 srt-4 three days ago and i really love this car. I have had alot of cars but this is by far my favorite. Well anyway I was just looking around underneath and saw that there is a little oil comming down from the I.C pipping on the driver side where the metal connects to the rubber hose. Anyone else have this and is it a big problem?
Old Nov 2, 2006 | 11:42 AM
Burnnout's Avatar
Burnnout
Default RE: oil leak
If the oil is leakin out of the intercooler piping, then I'm assuming the car doesn't have a catch can on it....my first suggestion would be to clean out the intercooler and then i would make sure the hose is pushed all the way up onto it and clamp it down....then go buy a oil catch can.... if you are unfamiliar with this, search the forums there is plenty threads to explain
Old Nov 2, 2006 | 03:48 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Might want to check your throttle body as well and clean that out too.........
Dusty
Old Nov 3, 2006 | 03:17 AM
joshgish's Avatar
joshgish
Thanks guys I will try that and no I haven't put the cc on yet. I was reading about it though.
Old Nov 3, 2006 | 06:24 AM
tenzunit's Avatar
tenzunit
tighten the clamp that holds the pipe to the intercooler. not a huge problem, but, will cause you to have a boost leak. that could be why you have a drop off in boost. oh yeah catch can is a good idea too, but not necessary.
Old Nov 3, 2006 | 06:51 PM
Plan B's Avatar
Plan B
ORIGINAL: tenzunit
Not necessary if you don't mind drowning your TB and everything downstream w/ oil.....
Old Nov 3, 2006 | 07:04 PM
talisman's Avatar
talisman
I put a throttle body on my car, the car only has 3,000 miles. The old throttle body had nice new fresh oil all over it. The next day I installed the catch can.
Old Nov 6, 2006 | 12:52 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
I have the $30 CC and I still have oil getting into my IC. I'm going to order a JMB CC. Eff the ghetto crap!
