Mess-up??????
Old Nov 5, 2006 | 07:02 PM
rare04's Avatar
rare04
Default Mess-up??????
Washed the car today and the engine and now the car is all jacked up. The car is missing and when I try to boost man it feels like its going to blow up. sounds like the turbo is coughing out the intake, water obiously water got in somewhere. anyone had this problem yet? man something really f--ked up here! thanks forum.
Old Nov 5, 2006 | 08:35 PM
talisman's Avatar
talisman
Default RE: Mess-up??????
Never, ever wash an electronically controlled engine like this. You can clean piece by piece but don't hit it with a hose or any type of engine cleaner. I quit allowing that at my dealership 20 years ago. Water gets into electrical connections and screws everything up. Start diconnection connections and drying them out with air or some other way.
Old Nov 6, 2006 | 12:02 AM
blue_srt4's Avatar
blue_srt4
u got water in the spark plugs and probably shorted the plug wires. this happened to me before. when u wash the engine u need to blow the water out of the wire and plug after washing.
Old Nov 6, 2006 | 01:28 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Back in the old days you could get away with a steam clean of your engine if you covered the plug wires, the coil, and the distributor.
Now I just use a sponge and a LITTLE soap and water........progress is great........, I think.
Dusty
Old Nov 6, 2006 | 04:17 AM
LilSparkPlug's Avatar
LilSparkPlug
In my 2.5 years of detailing I've never ever had a problem with powerwashing or hosing down an engine. Well except once, on a 1995 Jeep Grand Cherokee, I moved the throttle cable a bit. No big deal.
I soak my car with simple green, put a bag around the intake and "mist" the water onto the engine. Comes out just fine for me, with no issues whatsoever.
Old Nov 6, 2006 | 10:32 AM
fivetoez's Avatar
fivetoez
i never let my engine bay get dirty enough to warrant a hose down................not that i would anywayz........electrical componets & H2o= problems.
Old Nov 6, 2006 | 06:50 PM
talisman's Avatar
talisman
I had to quit letting my Technicians do engine cleaning because the dealership couldn't afford the lengthy, time-consuming comebacks associated with getting the electronic controls wet on the cars back in the 80's. Clean it piece by piece, cover up electric connections and if you want to use pressure plan on having a problem.
Old Nov 7, 2006 | 01:56 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
IF you choose to wash the engine with a hose, plan on unplugging connections and letting the car sit for a while to dry out
or lots of plastic, rubber bands and zip ties to block off the places you dont want water
then again if you have a few hours, piece clean it
Old Nov 7, 2006 | 02:53 PM
rare04's Avatar
rare04
Took the car apart ( intake, catch can, connectors, ignition and so on). Runs great now. Think I got the filter a little to wet, and its a long CAI. Oh well, all is good now. Thanks forum.
