turbo question
Old Nov 13, 2006 | 11:55 PM
PSI Chick's Avatar
PSI Chick
Default RE: turbo question
yup only slow red cars run s3......
Old Nov 14, 2006 | 11:13 AM
Burnnout's Avatar
Burnnout
That's what I thought you were gonna say
Old Nov 15, 2006 | 10:58 PM
gkg43's Avatar
gkg43
hey "psi chick", i saw your list of mods, but i didnt see any turbo upgrade anywhere...do you have a turbo upgrade???
and if not, how do you have 400whp and 11.5e.t.'s with the stock turbo?????
Old Nov 15, 2006 | 11:40 PM
gkg43's Avatar
gkg43
also, i am kind of confused about the agp turbo packages... i have the hp61 ball bearing turbo kit, and a few of the guys i was talking to asked me what size turbo that is... im really not sure, is that a t03/t04? or a gt??
Old Nov 16, 2006 | 04:53 AM
PSI Chick's Avatar
PSI Chick
i have the s3 turbo, not the stocker.
the hp61 turbo comes in many trims, so there's no way of telling what you have without looking at the turbo itself. here's the list of what agp offers for options on that turbo:
Compressor Specs:
- Polished T04E housing 3" inlet 2" outlet
- Polished T04S housing 4" inlet 2.5" outlet
- 61mm inducer 65lbs/min High Pressure compressor wheel
Turbine Specs:
- T31 4 bolt outlet turbine housing available in .48, .63, and .82 A/R ratios
- T3 5 bolt outlet turbine housing available in .48, .63, and .82 A/R ratios
- T4 On Center turbine housing available in .58, .69, .81, and .96 A/R ratios with 4 bolt outlet
- T4 Tangential divided housing available in .58, .70, .84, 1.00, and 1.15 A/R with 3" v band outlet
- T4 Tangential open (undivided) housing available in .58, .68, .81 and .96 A/R with 3" v band outlet
- 76 trim Stage 5 turbine wheel
- P trim turbine wheel
Old Nov 16, 2006 | 01:22 PM
hozay@N2MB's Avatar
hozay@N2MB
Edit - My mistake
Old Nov 19, 2006 | 04:17 AM
gkg43's Avatar
gkg43
hey "psi chick" what is the stage 3 turbo? is that from mopar? what is it, a bolt on turbo? how big is it?
Old Nov 19, 2006 | 01:37 PM
PSI Chick's Avatar
PSI Chick
it's a td05 w/td06 compressor wheel. go to moparperformance.com and you can read all about it
