Exhaust Cutout
Old Nov 18, 2006 | 05:38 PM
PSI Chick's Avatar
PSI Chick
Default RE: Exhaust Cutout
cut outs are the suck
Old Nov 18, 2006 | 06:32 PM
hozay@N2MB's Avatar
hozay@N2MB
^^ hater. Mad because S3 sucks.
Old Nov 19, 2006 | 01:41 PM
PSI Chick's Avatar
PSI Chick
just your s3 sucks
and most people that go to the track with a cutout runs slower with it open...so how is that not the suck?
Old Nov 19, 2006 | 04:43 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
so summary is: save for S2?
GOT IT
Thanks
Old Nov 20, 2006 | 06:41 PM
hozay@N2MB's Avatar
hozay@N2MB
S2 is far worse then S3.
Amy, how can you say people run slower w/ a open dump? Jeff (Bungles) run's consistent with it open and POOR when closed
Old Nov 20, 2006 | 09:04 PM
05SRTStage3's Avatar
05SRTStage3
Yes that is a good point...but I also that it was only my OPINION that is all and I do think that they suck....lack of back pressure and if I am not mistaken that shooting flames from cut out is also a sign of running LEAN.....and no Stage 3 ROCKS.....cut outs SUCK
Old Nov 20, 2006 | 09:06 PM
05SRTStage3
And also the tone ring problem is real if you didn't see the pics that i posted you should.....IT IS A REAL PROBLEM THAT I HAD....maybe you should read the previous forum of the pics
Old Nov 20, 2006 | 10:05 PM
Plan B's Avatar
Plan B
ORIGINAL: 05SRTStage3
Correct me if I am wrong, but doesn't the turbo itself create enough backpressure?
Old Nov 21, 2006 | 12:06 AM
hozay@N2MB's Avatar
hozay@N2MB
What in the world are you talking about? Backpressure? Do you even know how a turbo works? Running lean because of flames? my head hurts...i'll respond after I take an Aleve.
Old Nov 21, 2006 | 12:20 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: Plan B
You are correct, sir.
Dusty
