Wing Removal
ORIGINAL: flamingpinhead
ya, i put the iwng back on aswell. but it was nice to have it off for a couple months
ORIGINAL: LilSparkPlug
I've had the stock wing, no wing, and the AVS Downdraft. I <3 the stock wing. Its staying
You can pull up on it as well. After you loosen the nuts, just shut the trunk, and then pull/wriggle/wiggle/rock to your hearts content.
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
[IMG]local://upfiles/1628/B9F00B42548E438A91CF6352C26874E7.jpg[/IMG]
[IMG]local://upfiles/1628/A8EAD91FE6FD4355BB2335BCDC31912D.jpg[/IMG]
[IMG]local://upfiles/1628/D686F462AC2B4F758C1513E9B5FB1369.jpg[/IMG]
LOL yep they are glued on as well as those bolts. Looked to do the same thing a while ago to see if would make a difference to track times. If you want if off go with a carbon fibre deck lid or something. www.carbonbydesign.com
They are not glued on. The rubber gasket used has adhesive on the back side that attaches to the wing. Through the heat from outside temperatures on the metal of the car it spreads, making it seem as though its glued. I assure you, the wing is not glued to the decklid of the car.
OK, I got the wing off. I had to rock it to get it off. Mine had marks and cracks in the paint next to the holes. It looks like the factory over torqued the nuts. But I put the Red wing on my Black SRT. I like the looks, but my kids and there friends don't like it. They say it looks cheap.
