WHATS WRONG WITH MY SRT ?
Old Dec 10, 2006 | 06:00 PM
SOCAL SRT4's Avatar
SOCAL SRT4
Default WHATS WRONG WITH MY SRT ?
Well about a week ago my car went low on engine coolant,so i bought some(not mopar but same chemicals) so everything was good,but all of a sudden when im going WOT sometimes my car boggles out at 3k or 4k rpm,like if it wants to shut off,could it be my spark plugs???? thanks
Old Dec 10, 2006 | 06:13 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: WHATS WRONG WITH MY SRT ?
Are you throwing any codes?
Dusty
Old Dec 10, 2006 | 06:24 PM
SOCAL SRT4's Avatar
SOCAL SRT4
honestly i wouldnt kno because i havent taking it to a shop yet.my friends kept saying its not enough fuel going thru the lines and to chek my dist cap and spark plugs,you think it could be that???
Old Dec 10, 2006 | 07:45 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
go out to your car. turn the key forward (dont start it), turn it back, then turn it forward again (i think you do it twice). be ready with pen and paper, it will display a "P" code. write that bitch down and look it up here on the forum.
Old Dec 10, 2006 | 08:25 PM
moparman04's Avatar
moparman04
you have to flick the key 3 times... but yeah look it up here you will find your problem for sure
Old Dec 10, 2006 | 09:54 PM
SOCAL SRT4's Avatar
SOCAL SRT4
AH GREAT GUYS THANKS FOR ALL THE GOOD ADVICE,I WILL TRY SOME OF YOUR ADVICE RIGH TNOW,ILL LET YOU GUYS KNOW WICH CODE IT THREW OUT,YOU GUYS ARE REEALLY HELPFUL NOT LIKE THE OTHER SRT FORUMS:d
Old Dec 10, 2006 | 10:01 PM
SOCAL SRT4's Avatar
SOCAL SRT4
SO ARE LEETERS OR NUMBER GOING TO COME OUT??? CUZ I TRIED IT AND THE ONLY THING THAT SHOWED UP WAS THE ENGINE AND OIL LIGHT STAYED UP?? SORRY IM SUCH A NOOB WITH SRTS.AND DO I HAVE THE FLCIK THE KEY LIEK START IT BUT NOT STARTING IT OR JUST TURN THE KEY TILL THE CLUSTER TURNS ON ?? THANKS
Old Dec 10, 2006 | 10:44 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Do it three times within 10 seconds, all the way w/o starting it..........we were all nooby's at one time or another.......
Dusty
Old Dec 10, 2006 | 10:51 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: SOCAL SRT4
BTW, you don't have a distributor cap, or points, or a condenser. Just in case your friends tell you to check those..........
Dusty
Old Dec 10, 2006 | 11:01 PM
71RoadRunner's Avatar
71RoadRunner
The codes will be displayed where the odometer is and they will be the letter "P" followed by 4 digits.
What year is your SRT-4? It could either be a spark or fuel related problem or something else entirely. What, if any, modifications have you done to it?
