AGP catch can
Old Dec 12, 2006 | 01:47 AM
Kartman38's Avatar
Kartman38
Default AGP catch can
how well does the agp catch can really work.. do any of u think that some oil will still blow down into the intake with it installed?
Old Dec 12, 2006 | 02:41 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: AGP catch can
im assuming you mean the intake manifold? anyhoe... all the occ does is separate the oil from the air passing through it. the oil and junk is heavy, so it falls to the bottom of the can while the air simply passes through the top.
here is a ghetto sketch of it:
Old Dec 12, 2006 | 05:48 AM
Aceburner's Avatar
Aceburner
Is ther a real different between different types of catch cans. I was looking at the Greddy one but is AGP supposed to better in some way or another?
Old Dec 12, 2006 | 02:04 PM
flamingpinhead
Section Moderator
yes, they are designed differently. mine have the intake/outlet side by side, others they are at opposite ends or even different heights. i feel the best ones would have both inlet/loutlet on the same side with the outlet at the top and intake about halfway down. true it would need emptied more often than both at the top, but the oil and sludge would have less chance of being sucked UP and BACK than any other way.
Old Dec 12, 2006 | 02:52 PM
aalva79's Avatar
aalva79
Dont get the AGP, it blows ***, when i got it it had broken solder on it and the oil it was collecting was leaking into my belt grrr[:@] , listen to me and get any other type other than AGP they failed with the catch cans in my book.
Old Dec 12, 2006 | 02:59 PM
Kartman38's Avatar
Kartman38
I have a agp and the outlets are a different hieghts. I just dont want the oil comin in to be goin back out to the intake manifold. I was worrying if this was doin it.. and i put teflon tape on the bottom bolt to make sure it doesnt leak.....
Old Dec 12, 2006 | 03:27 PM
flamingpinhead
Section Moderator
yes, teflon tape everywhere. mine was initially not tight at the bottom and oil was leaking out onto my tranny. my wife was saying it wasnt catching anything, but here it was just leaking out. now its filling on up. im pretty happy with the NRG, although theinlet and outlet are sidebyside. i kinda ruined my other one by stripping out the plug hole BAH!!! guess i could have someone weld it shut???
Old Dec 12, 2006 | 03:33 PM
aalva79's Avatar
aalva79
it did not leak from the bottom screw but from the solder itself it had small holes.
Old Dec 12, 2006 | 03:39 PM
flamingpinhead
Section Moderator
ORIGINAL: aalva79
oh snap, and you paid 100 bucks for that POS??? did they send you a new one or refund you??? thats their workmanship and they should stand behind it.
Old Dec 12, 2006 | 05:21 PM
Kartman38's Avatar
Kartman38
ight.. yea i havent checked around mine.. thanks for the warning
