anyone else experience this??
Old Dec 16, 2006 | 07:09 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: anyone else experience this??
ORIGINAL: PSI Chick
lol no he probably had no idea why it was freaking out and made something up so he didn't sound like an idiot
yeah, so now i sound like the dumbass. thanks there sevice manager[:'(]
Old Dec 17, 2006 | 11:58 AM
redevil's Avatar
redevil
same thing happened to me, put on a boost contoller and was spiking too high so 3 hoses blew out(dumbass)....had to use the e-brake, eventually I putted clamps and Tie racks on all of them..haven't happened ever since
Old Dec 17, 2006 | 07:36 PM
flamingpinhead
Section Moderator
why would you need to use your ebrake? when experiencing this problem the brakes worked fine, just throw the car in neutral and let it rev itself until its content.
Old Dec 18, 2006 | 01:45 PM
redevil's Avatar
redevil
not really bro....remember 3 hoses blew out....one of them had to do with the brakes and i was going 40mph and a red light up ahead.when i parked the car kept reving for about 30 sec then i shut the car off and tied all 3 hoses back.
Old Dec 18, 2006 | 04:18 PM
PSI Chick's Avatar
PSI Chick
you blew the brake booster line. that's unrelated to the tps issue.
Old Dec 18, 2006 | 05:08 PM
04blksrt's Avatar
04blksrt
that's the cause to my car idling funny though i know 4 sure. could it possibly be the casue of loss of boost? i mean it is a vacuum hose??right?
Old Dec 18, 2006 | 05:25 PM
PSI Chick's Avatar
PSI Chick
the tps sensor you mean? if it fell out of the hole, then sure. otherwise, no.
Old Dec 18, 2006 | 07:40 PM
04blksrt's Avatar
04blksrt
it didnt fall...it broke. so i need to know if i have to replace the whole vacuum rail or what my options are...superglue didnt work very long
Old Dec 19, 2006 | 02:54 AM
PSI Chick's Avatar
PSI Chick
the sensor itself broke???? how did that happen??? you have to replace the sensor then....
Old Dec 19, 2006 | 01:59 PM
04blksrt's Avatar
04blksrt
its not the sensor. follow your # 3 sensor from the intake box down to the turbo. (its a blue hose). at the other end it connects to the vaccum port coming off the turbo right below the stock converter valve. i cant remember the correct terminology for it, but there is a plastic tit that the rubber nipple fits right over. that tit is what broke off inside the nipple..if anyone could give me that correct terminology so i could call the dealer and get a new one that would be great. if you have the mopar BOV conversion kit its the #6 part on the picture of the turbo on the backside of the installation instructions
