belt squeal
Old Dec 17, 2006 | 12:38 PM
deepseastetson's Avatar
deepseastetson
Default belt squeal
i bought a 04 srt-4. it has a stage 1 turbo upgrade on it. whenever i drive it it has a chirping kind of squeal comming from the engine. the squeal gets louder as i accelerat. i got some belt dressing but it didnt help. what could this be?
Old Dec 17, 2006 | 02:26 PM
mike9fore's Avatar
mike9fore
Default RE: belt squeal
Belt Tensioner.....
Old Dec 17, 2006 | 07:02 PM
deepseastetson
belt tensioner huh. cool i thought maybe it had something to do with a pulley. the belts are good i know that. its hard i am a newSRT owner and i dont have a owners manual and i cant find a service manual anywhere.
Old Dec 17, 2006 | 08:06 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
owners manual dosent tell you **** anyhow. best to get a dealer service manual, it makes the hayes manual look like a coloring book. anyhow, just get the belt tension corrected and youll be fine
Old Dec 17, 2006 | 10:41 PM
deepseastetson
i dont mean to sound like a dork , but what is wrong with the belt tensioner to make it squeel. its a constant squeal it never goes away. it also has a louder squeel somtimes that only does it when i first drive it for a few seconds and than goes away. the squeal i am worried about is the constant chirping squeal that never goes away.
thanx for the posts
Old Dec 19, 2006 | 12:19 PM
mike9fore's Avatar
mike9fore
ORIGINAL: deepseastetson
thanx for the posts
The Belt Tensioner keeps the belt tight.....the sound you hear is the belt slipping.....
Old Dec 19, 2006 | 06:11 PM
deepseastetson
ok i checked it out. the belt is way loose like you said. so i need to tighten the belt tensioner. i am working with no manual at all and i am not framiliar with this engine. i have always had Eupopen imports.
i can see on the altinator a couple of bolts/ are these the ones i need to tighten. i know on other cars i have had to loosen a couple of bolts and the tighten one but witch are they. and also how tight should i make it.
THANK YOU FOR ALL YOUR POSTS.
