anyone else experience this??
Old Dec 15, 2006 | 12:06 PM
04blksrt's Avatar
04blksrt
Default anyone else experience this??
my car has started idling a little funny. when im slowly driving and come to a stop and push the clutch (rpm's at about 1500), my rpm's will come down to around 1200 and then slightly go back up. and sometimes my car will idle at 1000 (too high for me), and sometimes it will idle at 800. first thing in my mind was vacuum leek. couldnt find any loose hoses. this morning while it was idling at 1000, i pushed the brake with no reaction, and while holding the brake i pushed the clutch in and the rpms dropped back to where they need to be. anyone experienced this or have any idea what that might be??
Old Dec 15, 2006 | 12:59 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: anyone else experience this??
TPS sensor / wiring is bad.
Old Dec 15, 2006 | 01:15 PM
04blksrt's Avatar
04blksrt
what is the tps sensor?
Old Dec 15, 2006 | 01:23 PM
PSI Chick's Avatar
PSI Chick
throttle position sensor
Old Dec 15, 2006 | 03:08 PM
04blksrt's Avatar
04blksrt
I promise im not an all around idiot.....just about cars
Old Dec 15, 2006 | 04:25 PM
flamingpinhead
Section Moderator
yeah, the TPS gets confused and youll pull up to a stoplight, put in in nutral and be running like 2500 RPMS, its quite embarassing. it took the dealer 3 times to fix mine, but at least i got new plugs and wires out of the deal
Old Dec 15, 2006 | 04:28 PM
PSI Chick's Avatar
PSI Chick
it doesn't get confused. the ground wire is too short and eventually breaks inside the rubber.
Old Dec 15, 2006 | 06:04 PM
04blksrt's Avatar
04blksrt
i need to check and see if this is covered or not. i hope the fact that i just cut out my cat wont change anything.....what do yall think??
Old Dec 15, 2006 | 07:35 PM
flamingpinhead
Section Moderator
ORIGINAL: PSI Chick
ok, so the dealer fibbed to me, no suprise
maybe he was trying to put it into laymen terms?
Old Dec 15, 2006 | 11:52 PM
PSI Chick's Avatar
PSI Chick
lol no he probably had no idea why it was freaking out and made something up so he didn't sound like an idiot
