rattle noise
Old Dec 16, 2006 | 11:58 PM
srtbris's Avatar
srtbris
Default rattle noise
my 05 srt-4 makesa rattling noise sounds like it comes from under at idle but if I rev my motor it gets faster and goes away when I rev open the hood it sounds like its coming from behind where the turbo is need help or suggestions
Old Dec 17, 2006 | 01:06 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: rattle noise
can you better describe the rattle? i mean it could just be something loose, a bolt or something that is causing some metal on metal rattle caused by the motor's vibration at cetrain rpms. or if its a different kind of rattle it could be something a little more serious. is it the coming from the turbo or somewhere nearby it?
Old Dec 17, 2006 | 05:42 PM
srtbris's Avatar
srtbris
it sounds like kinda like metal but gets faster as you go faster it goes faster
Old Dec 17, 2006 | 07:28 PM
flamingpinhead
Section Moderator
does it get faster with mph or rpms? if your at highway speed im assuimg its fairly bad, but does it quit when you push in the clutch and put the car in neutarl? its probably a vibration from something being loose. just isolating it and getting it torqued down is all. do you have any mods already? as long as its not a valve tap it should be really hard to fix. i would poke around under the hood to see if you can find anything that is loose
