AGP block off plate ?
Old Dec 18, 2006 | 08:30 PM
talisman's Avatar
talisman
Default AGP block off plate ?
So, I bought the AGP block off plate along with the hard pipes and a new blow off valve. The question is why doesn't AGPsend you a gasket with the block off plate ? Can I just use the same gasket from my old blue plate I'm removing ? One person told me the block off plate doesn't need a gasket or sealant but I've never seen 2 pieces of metal be airtight without a gasket.
If I use a copper type high temp sealant is there any chance of that sealant getting into any part of the engine, or turbo and causing a problem ?
What is the best way to be sure the BOP is sealed tight ?
Old Dec 19, 2006 | 02:47 AM
PSI Chick's Avatar
PSI Chick
Default RE: AGP block off plate ?
there's no gasket necessary. just use the copper rtv around the edge and stick it on. just let it dry for an hour or so before driving if you can to let it settle, then you'll be good to go!
Old Dec 19, 2006 | 07:55 AM
talisman's Avatar
talisman
Sounds good PSI, with the holidays coming up it may be a few weeks but if the weathers nice one day I'll be out under the hood. Thanks much !!!
