whats everyone's MPG?
Old Dec 22, 2006 | 03:21 AM
  #21
srt4babe's Avatar
srt4babe
Default RE: whats everyone's MPG?
18-22 No matter what, but I am a crazy ***, so it could be better if I tried harder
Old Dec 22, 2006 | 11:31 AM
  #22
YeahItsAHemi345's Avatar
YeahItsAHemi345
I drive like a maniac and I usually average 250-300 milesa tank. That's with Stage 1, WGA, SRI and no cat!
Old Dec 23, 2006 | 04:23 AM
  #23
Pressurecooker's Avatar
Pressurecooker
High teens low twenties, but I drive like I mean it. I got 27 on a highway trip once staying a strict 70mph. If you can drive around while keeping the boost gauge in the negative, you will do pretty good.
Mobil one oil or synthetic is a must. I also run Redline synthetic in the tranny and it shifts much, much better.
Old Dec 24, 2006 | 02:27 AM
  #24
LowSlowNeon's Avatar
LowSlowNeon
ORIGINAL: PSI Chick
if you're going to go to a regular parts store just give them the plug number and DON'T tell them what car it's for. they're too stupid to understand and they'll just argue with you that those plugs don't fit. if you can't get them locally, get them online. get either the 8.5mm or 9.0mm wires. it doesn't really make all that much of a difference.
LOL. I had that exact problem. The part guy was like you need this plug. And I said, no I don't. So I called a different store and asked if they had the part number I was looking for and went and got them. Can't believe you guys are only getting high teens low 20s. I get pissed when I only get high 20s. And I usually wrap out at least one gear every time I drive. Eh, well if I ever make my a reality of my dream I'll probably be in the same boat as all of you. HAHA.
Old Dec 24, 2006 | 03:02 AM
  #25
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: dustyloins
And empty out that trunk and make sure your tires are inflated to the recommended pressure (or maybe a pound or two higher)....the colder the weather, the more your tire pressure drops.
Dusty
So very true. I just adjusted my tire pressure at the beginning of this past week and they were all 5 psi low as they should be with the weather change, so I aired them back up to 35 psi where they should be. You need to do the opposite when the warm weather comes back as the tires will then be overinflated.
I run only Mobil 1 in my SRT-4 and I have all the mods I listed to improve fuel mileage as well as performance and then some.
