tires
Old Dec 19, 2006 | 07:02 PM
mopar222's Avatar
mopar222
Default tires
Would a 225-50-ZR17 fit on a stock rim and stock suspention setup. Really don't want to do the research if someone has a quick answer. Thanks in advance.
Old Dec 19, 2006 | 07:53 PM
jac05srt4's Avatar
jac05srt4
Default RE: tires
got them on mine
Old Dec 19, 2006 | 10:23 PM
Plan B's Avatar
Plan B
Default RE: tires
You guys are more daring than I am, seems a little wide of tire to throw on the skinny stock rims.... I am currently running the size tire mentioned above, but it is also on a 7.5 inch widerim....
Old Dec 19, 2006 | 11:58 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: tires
no way in hell i would put 225s on a 6" rim
Old Dec 20, 2006 | 04:10 AM
PSI Chick's Avatar
PSI Chick
Default RE: tires
no that's not a safe size to run on the stock rims. plus the sidewall is too high and will throw off your speedometer.
Old Dec 20, 2006 | 12:35 PM
Jims04srt's Avatar
Jims04srt
Default RE: tires
215/50s are the most you can safely run on the stock rim.
Old Dec 20, 2006 | 11:04 PM
mopar222's Avatar
mopar222
Default RE: tires
Thanks, had a really cheap set offered to me, that's why I was asking. Thanks again, I figured they probably wouldn't work but for the price it was very tempting.
