Belt tensioner
Old Dec 22, 2006 | 06:08 PM
deepseastetson's Avatar
deepseastetson
Default Belt tensioner
How do i tighten the belt tensioner. i have no manual or this would be a sinch. i can see where im suposed to lossen and tighten bolts on the back side of the engine. on the passenger side by the altenater. whitch bolts do i work on. i know from other cars i have worked on some bolts are loosened and then one is tightened. its really tight back in there and i could really use some advice.
Old Dec 22, 2006 | 08:49 PM
fullbuilt's Avatar
fullbuilt
Default RE: Belt tensioner
loosen the one on the side turn down the one on the rear then tighten the one on the side
