Sway&strut bars
Old Jan 2, 2007 | 04:53 PM
redevil's Avatar
redevil
Default RE: Sway&strut bars
when your car was kinda stock, let's say like mine, how did you launch it? I've never taken mine to the track yet, Moroso has been closed for a month or so and all I get to race is 2nd gear rolls.I'd like to know if there's some kind of trick to launch it, I've tried and I wheel-hop 1st and 2nd finally in 3rd i get some traction
Old Jan 2, 2007 | 05:23 PM
PSI Chick's Avatar
PSI Chick
when i was on street tires i usually went from around 1800 rpms and feathered it until i got traction. i never floored it until i was at least in 2nd and in full traction, which netted me 2.0-2.1 60' times. it takes practice and seat time that's all.
Old Jan 2, 2007 | 05:42 PM
redevil's Avatar
redevil
did this hurt your 1/4 times too much, wut do you think my time might be basing on my mods and doing what you just said and powershifting.This might be a stupid question but at least it will give me some kind of an idea wut to expect
Old Jan 2, 2007 | 05:50 PM
PSI Chick's Avatar
PSI Chick
i did a 13.8@101 stock.
the only power mods that you have are an exhaust and wga, and i'm not sure what boost you're holding. with those mods i wouldn't expect more than a 13.5 on streets probably.
Old Jan 2, 2007 | 05:51 PM
redevil's Avatar
redevil
k thanks for all...won't bother u no more
Old Jan 2, 2007 | 06:10 PM
PSI Chick's Avatar
PSI Chick
welcome
Old Jan 8, 2007 | 11:43 AM
redevil's Avatar
redevil
hey one more question about the the lower control arm busing upgrade.Is this somehting I can do myself?Do I need to buy new bolts for the new motor mounts?I wanna get everything right, I'm gonna buy everything this friday, hopefully a set of drag radials too
Old Jan 8, 2007 | 02:38 PM
PSI Chick's Avatar
PSI Chick
the lca bushings can be done yourself if you have a press. if not, then someone will have to press them in for you.
the bolts depend on which mounts you get. when you order it should tell you if it comes with new bolts or not. if it doesn't, definetly get the upgraded bolts.
Old Jan 8, 2007 | 03:03 PM
redevil's Avatar
redevil
you told me you have metal ones instead of plastic....are those a lot more expensive?is there a big diff between yours and the ones I'm gonna buy?
Old Jan 8, 2007 | 03:51 PM
PSI Chick's Avatar
PSI Chick
you can't get the metal ones anymore, the company that made them is no longer around. the rage plastic ones are the only ones availible anymore. i have not used the rage ones so i can't tell you if there's a big difference. the metal ones that i have are what most people around here have since the company that made them was in new jersey, so we all just went and got them.
