one month later
Old Jan 4, 2007 | 01:14 AM
jac05srt4's Avatar
jac05srt4
Default one month later
finally after a month, my car is back to normal. it turned out to be the boost gauge making the noise i was hear near the firewall. i knew the gauge was messed up by the readings, but i would have never guessed it would have caused such a grinding noise. even though it tooka month, i got a new wastegate, new vac lines, and all of my connections tightened. for those of you that gave your input, thanks. it helped me and the mechanic out a lot.
Old Jan 4, 2007 | 05:03 AM
PSI Chick's Avatar
PSI Chick
Default RE: one month later
glad that it got worked out finally
Old Jan 4, 2007 | 01:58 PM
jac05srt4's Avatar
jac05srt4
i have to say, it feels great to have my car back. i am sure there were boost leaks because the boost moves up a lot quicker than i remember and it seems to hold a lot better at higher numbers. thanks again everyone, i am sure this wont be the last time i need help. i plan on keeping this car for a long time. plus i plan on buying the tear down manual from the dealership soon, so if i can in return help anyone else out, let me know.
Old Jan 4, 2007 | 02:02 PM
PSI Chick's Avatar
PSI Chick
i have the manual is pdf files if you want them.
Old Jan 4, 2007 | 03:15 PM
jac05srt4's Avatar
jac05srt4
i would greatly appreciate it. you can email me at jc61_bruno@yahoo.com
thank you very much for everything. i plan on making myself get to know my car better.
Old Jan 4, 2007 | 10:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I've got a version of that PDF file (in 3 or 4 parts)that I "borrowed" off of the other SRT forum. I can send it, but it will take awhile, since I have dial up internet service........
Dusty
Old Jan 5, 2007 | 03:39 AM
PSI Chick's Avatar
PSI Chick
http://www.maximumcars.net/hosted/sr...als/manual.pdf
the whole manual is there, just download it.
