replacing stock boost guage.
Old Jan 6, 2007 | 11:21 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default replacing stock boost guage.
when you replace the stock boost guage can u just pull it out from the pod or do you have to take apart the entire dash? mine likes to flutter very bad under heavy throttle and it pisses me off cus i cant tell what i spike but when it holds its not shaking around..
Old Jan 7, 2007 | 01:47 AM
talisman's Avatar
talisman
Default RE: replacing stock boost guage.
You have to pull the top of the dash off. Disconnect the battery ground 1st, then remove the "A" pillars, then you have 2 screws in the defrost vent and 2 on each end of the dash top,then just push it up.
Old Jan 7, 2007 | 04:35 PM
PSI Chick's Avatar
PSI Chick
if your gague is fluttering it's probably because you have a boost leak. try fixing that first.
Old Jan 7, 2007 | 09:43 PM
talisman's Avatar
talisman
The stock gauge is just a step above junk. Mine fluttered / shook/ bounced all around on acceleration too until I replaced it. It's been steady ever since.
Old Jan 8, 2007 | 12:35 AM
MAssSrTdriven
no leaks, it will steady out and hold it only flutters while spiking, its just the stock unit so its junk.. ive heard tons of stories
Old Jan 8, 2007 | 10:13 AM
redevil's Avatar
redevil
I wanna get rid of mine too.Prob. this friday
Old Jan 8, 2007 | 06:22 PM
Valo2170's Avatar
Valo2170
i wish that was true saying it goes wayay if you get a new one. i have had 3 boost gauges all after market and they all flutter like crazy... i have had a boost leak test done over ten times and it still does it. but i think mine does it cause of the ****ing mm.
