Eventually losing boost.....
Old Jan 11, 2007 | 03:13 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Default Eventually losing boost.....
Just realized I haven't posted here in a while. Well here is the deal, I do alot of Touge (canyon runs) and I love it so [:'(]to those that dont. Well for some reason, I have been losing boost lately, wellatleast ever since I threw my stock intake pipe back on, I never had this problem with the AEM SRI. Let me explain, for the first 2 runs I am fine, then into the third run I gradually start losing boost to the point where at times I am only pushing 5 psi. Yes I open the hood and there is mysmore making super hot turbo glowing red in all of its glory, but I never really had a problem like this with the AEM. What do you guys think? Could it be the stock intake pipe not bringing in enough air?
Old Jan 11, 2007 | 03:15 PM
redevil's Avatar
redevil
Default RE: Eventually losing boost.....
boost leak
Old Jan 11, 2007 | 03:35 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
I dont think its a boost leak, cus if it was, and this is just my assumption, I would be losing boost at all times. I only lose boost after about 2 or 3 hard runs. Once it cools down its back to normal. On my drive home, back up to 15 psi.
Old Jan 11, 2007 | 04:16 PM
redevil's Avatar
redevil
put the AEM back on....and see if it does it again
Old Jan 11, 2007 | 05:16 PM
PSI Chick's Avatar
PSI Chick
heat soak
Old Jan 11, 2007 | 05:24 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Yeah I figured it was the heat, just needed confirmation. Anything you recommend me to do to help this out PSI Chick?
Old Jan 11, 2007 | 05:28 PM
PSI Chick's Avatar
PSI Chick
there are way to keep it down.....first thing is a big fmic. w/i, thermostat and fan mod will also help.
Old Jan 11, 2007 | 05:30 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
I'm looking into a big fmic that will for sure be my next mod. Fan mod sounds good too... how do I go about doing that?
Old Jan 11, 2007 | 05:37 PM
PSI Chick's Avatar
PSI Chick
find the blue w/pink wire and tap into it. run it into the cabin, hook it up to a switch and mount it. that's it!
Old Jan 11, 2007 | 06:25 PM
04blksrt's Avatar
04blksrt
psi....i would like to contract you out. ill fly you to the Ham, put you up in a 5 star hotel and pay you perdium. im gonna put x amount of $ in your hand and tell you to go to town!!!! what you think? seriously though, how long you been workin on these things and is this the first car you've messed with or did you have prior knowledge of cars b4 the srt?
