Stage 2 and a Wideband
Old Jan 13, 2007 | 09:41 PM
prpaster's Avatar
prpaster
Default Stage 2 and a Wideband
Since i have a Stage two and it doesnt read the downstream o2 sensor i can just disconnect it and but a wideband in there and there shouldnt be a problem Correct?
Thanks
Paul[/align]
Old Jan 13, 2007 | 10:42 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 2 and a Wideband
yupers
Old Jan 21, 2007 | 03:30 AM
motorboy1's Avatar
motorboy1
Can the same be done if I have a stage 1?
Old Jan 21, 2007 | 06:25 PM
PSI Chick's Avatar
PSI Chick
yups
Old Jan 22, 2007 | 01:14 PM
04blksrt's Avatar
04blksrt
not sure if you remember my setup with my O2 sensor, but i replaced the cat with 2.5" pipe and a bong to plug the sensor into. now im really thinkin about a stage kit so my setup should work with the same with a stage kit as well correct?....also, how would i go about findin the MAP and TIP sensor if i wanted to peice together my own stage 2?
Old Jan 22, 2007 | 02:01 PM
PSI Chick's Avatar
PSI Chick
you can get them from a dealer or try on srtforums, the come up for sale every once in a while.
and yes if i'm understanding you right it should work just fine.
Old Jan 23, 2007 | 09:28 PM
franknbeans's Avatar
franknbeans
Not sure, but if i recall correctly if you dissconnect the downstream O2 you will toss a code. Leave it connected and just zip tie it up real good.
Old Jan 23, 2007 | 11:10 PM
MChat's Avatar
MChat
ORIGINAL: franknbeans
That is correct. The Stage ECU's will throw a code if the sensor is missing, but they don't care what the O2 is reading.
Old Jan 24, 2007 | 01:58 AM
motorboy1's Avatar
motorboy1
OK cool that helps guys thanks but on a different note... How does placing the o2 sensor there effect the reading on the gauge? Other words how accurate is it being its inside the cat.
