map clamp
Old Jan 14, 2007 | 01:11 PM
redevil's Avatar
redevil
Default map clamp
A friend of mine bought one a couple weeks ago and wants to sell it to me.He never installed it, he wants $40.Is this a good deal?Do I need to tune the car to install this?
Old Jan 14, 2007 | 04:13 PM
PSI Chick's Avatar
PSI Chick
Default RE: map clamp
don't waste your money.
yes you have to tune, you need a a/f gauge at the minimum. but in the end, you'll just end up dumping it for something else and it's not worth the risk of blowing your motor if it's not set properly.
Old Jan 15, 2007 | 01:17 PM
redevil's Avatar
redevil
what if I buy that wideband a/f gauge...and tune the car properly through that?Besides I'm only gonna have that on for a couple months untill I find somehting better.I bought it already so I dunno what to do.....you think with the wideband set properly then I should be allright?
Old Jan 15, 2007 | 01:47 PM
PSI Chick's Avatar
PSI Chick
yea if set properly but with no fuel mods you're not going to be able to adjust much
Old Jan 15, 2007 | 01:52 PM
redevil's Avatar
redevil
what mods are you talkin about???I wanna get it right....I very organized when it comes to cars
Old Jan 15, 2007 | 02:00 PM
PSI Chick's Avatar
PSI Chick
then don't be cheap and get a real fuel controller! lol
look map clamps only end up blowing motors in my experience. they can only clamp the voltage at one point, and that causes a lean condition usually up top because if the ecu is thinking that there's lower boost it will pull fuel. without at least a pump to bring the volume higher it can get dangerously lean and fry the rings.
Old Jan 15, 2007 | 02:04 PM
redevil's Avatar
redevil
i did buy a S-AFC but the guy never sent it...still waiting for it!!!I got it on e-bay, you know how that goes.
Old Jan 15, 2007 | 07:08 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
PSI, would the FPR mod work instead of forking up the $$$ for a Walbro?
Old Jan 15, 2007 | 08:03 PM
PSI Chick's Avatar
PSI Chick
the fpr mod does work, however there is a debate going out the long-term effects of using it in terms of injector duty cycle and life span. increasing fuel pressure also doesn't do much if your injectors are still running on the same duty cycle, all it does is back up the system (especially with no return line). so you're increasing pressure which could harm both your injectors and your fuel pump by making them work harder than they were designed to work.
now using the fpr along with a pump and injectors to control fuel output does work, not as efficently as a fuel control device, but it works. on the stock system however it isn't THAT effective.
Old Jan 16, 2007 | 12:23 PM
redevil's Avatar
redevil
what kind of fuel control devise do you use?
