greddy bov fits???
Old 01-15-2007, 03:03 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
Default RE: greddy bov fits???
and which bov are you using.....is it the greddy type rs?...look like a blue horn or something?
Old 01-15-2007, 03:05 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
yea i have the greddy rs and have had it for the last like two years with no problems.
Old 01-15-2007, 03:10 PM
redevil's Avatar
redevil
redevil is offline
what are you getting now?...sell me the greddy...you think it will mount good on the turbonetics cold pipe?
Old 01-15-2007, 03:13 PM
redevil's Avatar
redevil
redevil is offline
you mind teaching me how to set my raptor....i dunno how tight the screw on top has to be...I'm spiking 20 psi and starts falling down at 4500 5000 rpms.Sometimes it hold 16 psi..and 17psi.But the boost gaugue is not good and I have a boost leak.
Old 01-15-2007, 03:14 PM
PSI Chick's Avatar
PSI Chick
well fix the boost leak and the gauge first lol. the bov should be releasing pressure at 0. anything else and it needs to be adjusted. just watch when it blows off.
i have a turbosmart supersonic going in.
Old 01-15-2007, 03:46 PM
04blksrt's Avatar
04blksrt
04blksrt is offline
i can probably get you this greddy if you want it....that is if i can get the raptor with the pipes
Old 01-15-2007, 05:24 PM
redevil's Avatar
redevil
redevil is offline
when you say adjusted you mean tighten or loosen...did you use the 15 psi spring or the 10?
Old 01-15-2007, 05:28 PM
redevil's Avatar
redevil
redevil is offline
what do you mean releasing at 0.Sometimes when I'm driving slow and the car is in vac she releases....but makes a diff. sound.Sound more like wosh..wosh..wosh(very fast).And when I'm boosting she sound like whooooosh
Old 01-15-2007, 08:07 PM
PSI Chick's Avatar
PSI Chick
a bov should not be releasing in positive pressure at ALL. if it is, you need to tighten it. what should happen is that when you give it slight gas and your boost gauge is at 0 that's when it should be releasing pressure. if it's releasing in vacuum then it's too tight, and in boost it's too loose.
Old 01-15-2007, 11:30 PM
Burnnout's Avatar
Burnnout
Burnnout is offline
The fast woosh woosh woosh sound is probably intake flutter he is hearing......
Quick Reply: greddy bov fits???
