miss fireing system
Old Jan 19, 2007 | 02:06 AM
SRT_YA's Avatar
SRT_YA
Default RE: miss fireing system
and why would you want this?? are you a rally racer? I'm just curious... it seems like a lot of work for little gain on a street car???
Old Jan 19, 2007 | 03:12 AM
2jzkilla's Avatar
2jzkilla
well i only race on a down hill
Old Jan 19, 2007 | 05:45 AM
waylon's Avatar
waylon
Member
i have only ever know this to be done in rally cars or other actual race cars and never in an srt-4 but if you want i can get you in touch with someone who i know has done the anti-lag in his rally car...its not a dodge though its an evo III
Old Jan 19, 2007 | 12:54 PM
04blksrt's Avatar
04blksrt
thats a cool concept, but i dont think a srt would need all that....boost lag is not that bad and ive heard of people having issues when they start messing with the firing systems on these cars
Old Jan 19, 2007 | 02:54 PM
PSI Chick's Avatar
PSI Chick
ORIGINAL: 2jzkilla
wtf? you're really starting to sound like a troll.....
Old Jan 20, 2007 | 05:22 AM
2jzkilla's Avatar
2jzkilla
well thats me and i dont care if people dont understand me
Old Jan 20, 2007 | 07:18 PM
PSI Chick's Avatar
PSI Chick
you only race down hill? i'm sorry, but that's one of the most retarded things i've heard in a while...
Old Jan 20, 2007 | 07:20 PM
PSI Chick's Avatar
PSI Chick
ORIGINAL: 2jzkilla
i think i might have the answer i seek but for you who dont know what a miss fireing system is.
An anti-lag (commonly called a 'bang-bang' in WRC) worked to help keep a turbo spooled. When the driver lets off the gas the computer physically holds the throttle open, dumps in a ton of fuel, and retards the timing. This causes most of the fuel to not be ignited in the combustion chamber and ends up getting burnt in the exhaust manifold, creating the energy that helps the turbo stay spooled.
well to answer your question regarding this....unless you're a REALLY slow shifter and have a T66 or larger it would probably be pointless for drag racing. this isn't a system used in draging because it's not necessary. drag cars don't see low rpms that need the turbos to stay spooled. if you're shifting properly you don't get low enough in the rpm band to dump boost.
Old Jan 20, 2007 | 08:50 PM
mopar222's Avatar
mopar222
I think someone has been watching a little to much intital d. The evo III used it, and stated the rally car thing. Blah, blah, blah....They were racing mountain passes(remeber this is all a cartoon, and fictional) and the miss firing system was used to get the last bit out of the downhill run. Get a life.....1 are you really that good that you would need something like this? I doubt it. 2 Do you think people will think your cool cause your car backfires? I doubt it. 3 Do you really drive your car that hard and if so wouldn't other mods be more benifitial? like say lightening up the car? Well good luck with the hole misfiring thing.
Old Jan 21, 2007 | 02:34 AM
2jzkilla's Avatar
2jzkilla
what is initial D?
