what size tire can i use ?
Old Jan 26, 2007 | 07:06 PM
kpsrt4's Avatar
kpsrt4
Default what size tire can i use ?
my 2004 srt4 has eibach pro kit springs and tokico illumina adjustable-5's shocks. i want to get 18x7.5 rims. just wandering the tire sizes i might be able to use. ie. can i put 235/40/18 or would i have go go with 225/40/18 ?
Old Jan 26, 2007 | 07:37 PM
04blksrt's Avatar
04blksrt
Default RE: what size tire can i use ?
i think mchat said hes runnin 235...not quite sure but hes runnin 35mm or 38mm offset. so depending on your offset i believe u should be fine with 235, but i would deff. ask him. come to think of it, i think hes only runnin 17's. i dunno man....if noone replies on here the pm mchat or psichick
Old Jan 26, 2007 | 07:46 PM
blacksrtinAZ's Avatar
blacksrtinAZ
A couple guys here in AZ are running the 235/40/18's. And it depends on the offset.
Old Jan 26, 2007 | 08:04 PM
kpsrt4's Avatar
kpsrt4
the rim is a 18x7.5 with a 38 offset. or wandering if 17's are the way to go. i just think 18's will look better and have more grip.
Old Jan 26, 2007 | 08:22 PM
blacksrtinAZ
Grip is all about the type of tire. But those running the 18's swear by them
Old Jan 26, 2007 | 08:26 PM
Black 4's Avatar
Black 4
I am running 18x8 BBS with 225/40/18 and they work just fine. but they are right it depends on your offset. So with the right offset 235/40/18s will work just fine.
Old Jan 26, 2007 | 08:41 PM
Black 4's Avatar
Black 4
Remember these 2nd gen car that are disigned around 16s but 17s and 18 will work just fine.
Old Jan 26, 2007 | 11:46 PM
MChat's Avatar
MChat
ORIGINAL: 04blksrt
245/40R17 on a 17x8" wheel w/ a 35mm offset.
Old Mar 4, 2007 | 03:05 PM
silverblacksrt4's Avatar
silverblacksrt4
will 245/40/17 tire work on your stock rims??? if not 240? 235? i want the widest tire i can get..
Old Mar 4, 2007 | 04:47 PM
Aceburner's Avatar
Aceburner
That's exactly what I need to know, what is the highest we can go on the stock suspension and spacing. I'm looking into 225 or 235/18's. Anyone know if this will work on the stock rim?
