New motor mounts or inserts
Old Jan 30, 2007 | 07:58 PM
yorksrt's Avatar
yorksrt
Default RE: New motor mounts or inserts
no supposedly the factory bolts are already strong enough. they've been there for about 8000 hard driven miles and no problems yet-knock on wood
Old Jan 30, 2007 | 08:26 PM
talisman's Avatar
talisman
You all do understand that the factory designs mounts to AVOID vibration for a reason, more than the fact that most people don't want vibrations. Vibrations cause parts to wear out prematurely andbreak. The engineersdesign the cars for well thought out reasons. Unless you're planning on racing the car ( at the track ) I can't imagine any reason for installing solid mounts.The inserts do take up some of the slop in the factory mounts and while some people may say their a waste of money, the fact is they do help without causing other problems.
Old Jan 30, 2007 | 11:00 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
^i have never heard it quite put it this way, but its a good perspective, since its not really a 'race car' but its a daily driver. cant forget that
Old Jan 31, 2007 | 04:49 AM
PSI Chick's Avatar
PSI Chick
i'll take vibration and a little wear and tear over wheel hop any day. the stock mounts on our cars were not "designed" for us at all. they are the same mounts that are in the regular neon. so there was no thought put into them at all, they just used what was there.
