Stage 1 Install
Old Feb 4, 2007 | 02:56 AM
WASRT4's Avatar
WASRT4
Default Stage 1 Install
so i got my s1 and was wondering if theres a how to on it? any url's?
Old Feb 4, 2007 | 03:05 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Stage 1 Install
just replace the current pcm with the new one, and if your 03, replace the injectors. are you looking for like step by step barney style with picture how-to???
Old Feb 4, 2007 | 04:11 AM
WASRT4's Avatar
WASRT4
i have a 05, and yea barney is good. i havnt even had the time to search where the pcm is at. i dont have much time to f-off.
Old Feb 4, 2007 | 03:50 PM
04blksrt's Avatar
04blksrt
check on the srtforums.com....im sure they'll have a how to somwhere. i was talking 2 a friend yesterday and he has a s1...only advice he gave me was be extremely careful with the "clips", apparently theyre plastic and they break easilly. im assuming u'll know what im talking about when u get to it. thats the only thing i have 4 u....sorry
Old Feb 4, 2007 | 10:07 PM
WASRT4's Avatar
WASRT4
ok so i have takin the time to search and i cant find installation instruction, only problems with dealers and car acting badly? any suggestions?
Old Feb 5, 2007 | 01:01 AM
`71RR383SRT4's Avatar
`71RR383SRT4
Remember after you have the PCM installed. Drive it around for about 15-20 minutes to let the new PCM get 'adjusted'. When I put mine in I took it right out and hammered it. It didn't work real good. But after I drove it around for a while it got 'adjusted' to my SRT and now it works F`n GREAT!!!
Old Feb 6, 2007 | 01:39 AM
manninej's Avatar
manninej
I happen to be looking for a How To and found this
Stage 1 Install (4th post down) http://www.srtforums.com/forums/showthread.php?t=9532
Stage 2 Install (Computer part is probably the same) http://www.srtforums.com/forums/showthread.php?t=204082
Old Feb 6, 2007 | 11:06 PM
aiverson's Avatar
aiverson
I found this link with picture on stage 1 install on a 2003. hope this helps
http://www.sportcompactcarweb.com/pr.../photo_06.html
Tony
Old Feb 6, 2007 | 11:30 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
When makingengineadjustments (like a CAI, new exhaust, etc)on the SRT-4, disconnect the negative terminal on the battery for about 1/2 hour before driving off. This will let the PCM "forget" the old settings and accept the new ones........
Dusty
