noise from engine
Old Feb 6, 2007 | 10:54 PM
srtbris's Avatar
srtbris
Default noise from engine
maybe someone can HELP I hear a tap noise from behind the near the manifold. the noise is not the valves but when you rev the motor the tap gets faster and goes away not really loud but loud enough for me to hear it as the car gets warm the noise goes away . if any has a weird noise or have similar or have any advise let me know
Old Feb 7, 2007 | 04:08 AM
PSI Chick's Avatar
PSI Chick
Default RE: noise from engine
you're hearing your injectors.
Old Feb 7, 2007 | 11:01 AM
srtbris's Avatar
srtbris
the noise sound like it comes from back buy or under turbo you can hear it when the hood is closed and is noticable
Old Feb 7, 2007 | 12:02 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
if you have lots of mods, avoid the dealer... but if your under warranty you could have them take a look *haha. anyhow, our cars are not known for being quiet. what your hearing isnt that uncommon. like psi said bout, our injectors are noisy little boogers.
Old Feb 7, 2007 | 01:53 PM
PSI Chick's Avatar
PSI Chick
check your heat shield and the charge pipe.
Old Feb 7, 2007 | 03:45 PM
srtbris's Avatar
srtbris
as I give it gas the noise gets faster and its like a tapping metal aginst metal.
Old Feb 7, 2007 | 07:25 PM
PSI Chick's Avatar
PSI Chick
heat shield
Old Feb 7, 2007 | 07:48 PM
LilSparkPlug's Avatar
LilSparkPlug
I had the exact same issue in my car, and it was the lash adjusters. They also did the TSB to champer the cam caps while they were in there.
Old Feb 7, 2007 | 07:57 PM
PSI Chick's Avatar
PSI Chick
you actually let a dodge tech into your engine with a file? you're a braver soul than i......
Old Feb 27, 2007 | 04:23 AM
Trickdaddy988's Avatar
Trickdaddy988
Its most likely your cam gears and cam shaft i had the same prob. in my car
