bumper swap **updated with PICS**
Old Mar 25, 2007 | 05:59 PM
  #61
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: bumper cover swap **updated with PICS**
ORIGINAL: sexySRT04
I think the bumper swap is f****n ugly. You should change it back!! The car was made to look like it does for a reason.
the bumper cover is inthe garage, tail lights are in a box by the freezer... right near the socket set. and the creeper is hanging in the garage. jackstands and floorjack are somewhere in the garage should you need to lift it.
good luck
Old Mar 25, 2007 | 06:47 PM
  #62
silverblacksrt4's Avatar
silverblacksrt4
thank you someone agrees with me!!!
Old Mar 25, 2007 | 08:09 PM
  #63
sexySRT04's Avatar
sexySRT04
not a problem at all!!I guess ifI want it changed back I will have to do it myself... I can do it I have faith in myself
Old Mar 25, 2007 | 08:27 PM
  #64
flamingpinhead
Section Moderator
^well, the 01/02 swap idea will be getting dropped only AFTER i obtain my j-body project (that will satisfy my sleeper needs)
end goal is a 3400 swap and turbo kit on a car just like this one, should be a high 12s / low 13s car. will run mid-high 14s on the 3400 n/a until a turbo is obtained.
edit: the car WILL be retaining its STOCK appearance (maybe Z24 rims & brakes installed). no gay body kits or anything.goal here is to have a V8(and stock srt4) eating sleeper
only trick is going to be mounting an i/c and retain proper air flow and cooling on the stock bumper... but ill look into that once the car is here. its in PA right now (im in KS), so next opprotunity i can take ill go get it.
Old Mar 25, 2007 | 09:27 PM
  #65
djmagic's Avatar
djmagic
Plan B, it will bolt up just fine, if anything you have to trim the bumper so the tips fit snug. That's true though, black is stealth at night. Best colors, silver, black, blue, red and white and maybe yellow. The rest no.
Old Mar 25, 2007 | 10:48 PM
  #66
sexySRT04's Avatar
sexySRT04
[:@]Like I said I WILL DO IT MYSELF!!! Just like you told me, if I want it done I can do it. Your not driving it anyway I AM!!! love ya
