I NEED A MAP CLAMP FOR NEON SRT-4
Old Feb 12, 2007 | 11:30 PM
crazy driver's Avatar
crazy driver
Default I NEED A MAP CLAMP FOR NEON SRT-4
HI, I NEED INFO OF WHERE I FOUND A MAP CLAMP FOR MY NEON SRT-4 2003 (MAKE, MODEL) OF THE MAP CLAMP AND WHERE I FOUND IT. THANK'S FOR YOUR HELP!!!
Old Feb 13, 2007 | 05:14 AM
PSI Chick's Avatar
PSI Chick
Default RE: I NEED A MAP CLAMP FOR NEON SRT-4
don't get a map clamp, get a fuel controller, they're built in.
Old Feb 13, 2007 | 05:36 AM
NYYDYNASTY's Avatar
NYYDYNASTY
agreed. spend a little extra cash and get a fuel controller.
DTEC ... SAFC ... etc..
Old Apr 4, 2007 | 03:42 PM
Tricked95neon's Avatar
Tricked95neon
ok im having trouble with my car i just built up a 95 neon with stage 2 garrett and je pistons with the stage 2 srt4 injectors walbro 255lph pump and venom fuel rail i have the apexi neo for a fuel controller should i need a map clamp cuz it seems to run fine at idle and up to 4000 it sounds like its shutting off from seeing boost how should i tune my car can you give me some hints thank you
Old Apr 4, 2007 | 05:25 PM
prpaster's Avatar
prpaster
Do you have a Wideband or do you know your Air to Fuel Ratios?
Old Apr 4, 2007 | 07:43 PM
PSI Chick's Avatar
PSI Chick
the neo has a map clamp built in, don't clamp it.
what are your a/fs? if you're hitting fuel cut then you're running too much boost. lower it.
Old Apr 4, 2007 | 09:32 PM
Plan B's Avatar
Plan B
ORIGINAL: PSI Chick
I agree, sounds like some re-tuning of the Neo is in order. If you find any base maps for the Neo, let me know. Buddy just got one (for $200!), unfortunately before he got a wideband, and his car is running like crap! Tried to get him to sell it to me, but he won't
Old Apr 6, 2007 | 11:13 AM
redevil's Avatar
redevil
i got a map clamp....if you want it let me know
