OVER BOOST CUT OFF
Old Feb 15, 2007 | 12:14 AM
crazy driver's Avatar
crazy driver
Default OVER BOOST CUT OFF
HI GUYS, I HAVE A PROBLEM WITH MY CAR (NEON SRT-4 2003), WHEN I WAS RUNING IT, THE CAR GO TO 18PSI AT THE SAME TIME IT MAKE THE CUT OFF, AT ANY REVOLUTION. WHEN I SET THE WASTEGATE AT 13-14 PSI, THE CAR DON'T MAKE THE PROBLEM. PLEASE LET ME KNOW, HOW TO RESOLVE THE PROBLEM, THANK'S FOR YOUR HELP!!!
Old Feb 15, 2007 | 01:31 AM
motorboy1's Avatar
motorboy1
Default RE: OVER BOOST CUT OFF
I don't think Its really a problem its saving you from running lean and burning it up. I hit it a few times with S0 but I backed the boost down to stay away from it like you did! When I got my S1 I turned it back up, No more boost cut out but retarded timing instead.
Old Feb 15, 2007 | 04:12 AM
PSI Chick's Avatar
PSI Chick
yes that's not a problem. that's the ecu preventing you from blowing up your engine.
Old Feb 15, 2007 | 11:09 AM
redevil's Avatar
redevil
get a bigger fuel pump($100) and a map clamp($30)...or if you wanna do it right get a dtech or safc($350)
Old Feb 15, 2007 | 11:28 AM
PSI Chick's Avatar
PSI Chick
why even suggest the wrong way? map clamp ftl.
Old Feb 15, 2007 | 12:05 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Stage 2 pcm, map, tip and injectors. Case closed
Old Feb 15, 2007 | 01:19 PM
redevil's Avatar
redevil
maybe he's running low on money....who knows.Just giving him a few options
Old Feb 15, 2007 | 01:56 PM
YeahItsAHemi345
ORIGINAL: redevil
Figured I'd just give him the easiest way out. With that said...just keep the boost turned down...get a Walbro, or FPR mod from PTP. Other than that...whatever?
Old Feb 15, 2007 | 03:14 PM
redevil's Avatar
redevil
i know.You gave him the easiest way out and I gave him the cheapest.....i guess my post disapointed psichick.....sorry....please dont hurt me!![&o]
Old Feb 15, 2007 | 03:16 PM
NYYDYNASTY's Avatar
NYYDYNASTY
yeah, dont bother going the mapclamp route. just save cash and head down the dtec or safc route.
