turbo timer problem
Old Feb 15, 2007 | 03:54 AM
srt silver dragon's Avatar
srt silver dragon
Default turbo timer problem
does any one know what color or where the o2 sensor wire is located on the srt4 pcm/ecu im trying to hook up my turbo timer but i cant find a wiring diagram for the pcm
Old Feb 15, 2007 | 04:11 AM
PSI Chick's Avatar
PSI Chick
Default RE: turbo timer problem
http://www.carbide-red.com/pdf/srt4/168720_apexitt.pdf
that should help
Old Feb 15, 2007 | 06:08 PM
Plan B's Avatar
Plan B
Good post PSI, but it doesn't speak to the O2 sensor hook up., just everything else.
Silver - You will need an aftermarket Wideband if you plan on using the Automatic timer function on the Apexi TT (I assume this is the one you are reffering to since you are asking about the O2 sensor). I am ordering a wideband in the next week and plan on hooking up my Apexi TT to it, so i will post what I discover since I can't find directions on how to do it either...
If anyone else knows this process please post! It will save me a lot of trial and error, although it shouldn't be that difficult....
Old Feb 15, 2007 | 11:29 PM
PSI Chick's Avatar
PSI Chick
from what i remember, a wideband o2 sensor will not work. the issue with this tt isn't the reading of the o2 sensor, the stock one is perfectly fine for it to get what it needs. it's that the voltage that it's looking for is different from the one that we use, so it won't work. you would need to install a different o2 sensor that uses the voltage it's looking for (i think it's 0-5v).
