OK time for a new WGA, which one?
Old Feb 16, 2007 | 01:20 AM
jmsrt4's Avatar
jmsrt4
Default OK time for a new WGA, which one?
I have tried everything to see whats wrong with my boost (only between 5 and 7). Checked for leaks, found none. Checked all lines, everything is fine. I triedunpluged thebattery.My last option has got to be the wga. Hoping this fixes the problem, but which one do I get. Im still stock stage0, and only want stock boost (possibly a little more). I have heard that the agp may not be worth it considering what I want. If anyone can give me there opinion I would greatly appreciate it.
Old Feb 16, 2007 | 01:51 AM
satn_999's Avatar
satn_999
Default RE: OK time for a new WGA, which one?
see if you can find a cheap stage 2, that shoul suite your needs fine.
Old Feb 16, 2007 | 04:30 AM
NYYDYNASTY's Avatar
NYYDYNASTY
i have the slowboy racing wga (which is basically the Kinetic wga). anyway, its great. but with a stage 0 pcm, you'll throw an overboost code. if you plan on keeping stage 0 pcm, just replace your wga with another stocker.
Old Feb 16, 2007 | 07:01 PM
talisman's Avatar
talisman
I put a stage 2 w/g on my 2005 before I bought the Stage 1 computer, I got a little extra boost and never set a code.
Old Feb 17, 2007 | 05:00 AM
jmsrt4's Avatar
jmsrt4
i'm planning on getting the stage1 in the near future, would the s2 wga still be worth putting on?
Old Feb 17, 2007 | 10:33 AM
talisman's Avatar
talisman
If you're planning on Stage 1 and you do set a code with the Stage 2 W/gate, the Stage 1 computer will fix it. The stage 2 w/gate is a fine choice for what you're doing.
Old Feb 17, 2007 | 03:27 PM
PSI Chick's Avatar
PSI Chick
get an agp wga
Old Feb 17, 2007 | 04:54 PM
NYYDYNASTY's Avatar
NYYDYNASTY
AGP wga = more expensive but easier to tune
Kinetic wga = less expensive but a little harder to tune
Old Feb 17, 2007 | 05:35 PM
04blksrt's Avatar
04blksrt
that would sum it up perfectly for me dynasty! AGP is it . i have heard though that the older model agp's were a little easier to install and worked just as well. how true is this, and how do you guys fell about a used wga?
Old Feb 17, 2007 | 06:14 PM
NYYDYNASTY's Avatar
NYYDYNASTY
a used wga? umm .. it depends on the price. If its a good deal, then go for it. otherwise, just spend the cash on a new one. AGP wga's are easy to install. it shouldn't take you that long to get it installed. The tuning part might take you a little bit, since it gets really hot under the hood...otherwise, its no big deal
