Exhuast Question
Old Feb 20, 2007 | 08:31 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default Exhuast Question
when buying an exhuast should i be considering with a cat or without. or maybe a high flow cat? what would be the pros and cons of having a cat or not having a cat. im sure there would be a sound difference yes, but i just am wondering if its better to run with or without one when buying an aftermarket exhaust set up.
Old Feb 20, 2007 | 09:43 PM
NYYDYNASTY's Avatar
NYYDYNASTY
Default RE: Exhuast Question
it doesnt matter. Here, in NY, we can pass inspection without the cat's...i'm not sure about Mass. The major benefit of running catless, is that fact that you can run leaded fuel at the track. Otherwise, there's no reason to take it out. Yes, the exhaust flows a bit better without it, but for street driving, it wont matter that much.
Old Feb 20, 2007 | 10:05 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
pro of catless: flow
a little bit better sound
con of catless: inspection
cops
Old Feb 22, 2007 | 11:52 AM
silverblacksrt4's Avatar
silverblacksrt4
go without cat.. loud as hell!
Old Feb 22, 2007 | 01:59 PM
wannasupra's Avatar
wannasupra
or take a cat and have a good muffler shop weld a 3 inch pipe right through the bastard. be sure to get some kind of muffler tho, so it won't be so snappy
