Whats normal
#22
RE: Whats normal
I think i have it figured out. I was reading in the owners book that normal boost is between 11-15 PSI, however lower octane fuel will cause the car to boost less. With that being said is it safe to assume higher octane will cause the car too boost more? Im running octane boost in my car thats why im thinking maybe this is the reason shes boosting the way she is.
#23
#24
#27
RE: Whats normal
In order.
Octane boosters are a waste. Read closely, they say "RAISES OCTANE 2 POINTS!!!!!!' on the front. Upon closer inspection, it reads "Point is equivelent .1" Meannig that a whole bottle raises your octane by .1
So a tank of 93 octane with a bottle of octane boost ends up being 93.2.
The only additive proven to work as a real octane booster (and only really worth it if you need race fuel) is something called "Torco Race Fuel Accelerator" , or you can mix stuff up using toulene or xylene, but thats more chemical mixing than most folks want to do.
Millenum, what octane do you normally run? As far as leaks, how did you check ?
#28
RE: Whats normal
Most octane booster claim around 7-15 octane points gain, but in the small print on the back they explain how the larger gains are only possible by using the lowest octane to start out with. If you start out with 93-100 octane and put the additive into this, it will only give you 1-3 octane points if your lucky. If your gonna run an octane booster then fill up with the lowest grade crap you can find to get the most out of the booster or it's useless. Then again if you buy the good gas to start off with, it will be about the same octane as the cheap stuff with the booster, but it will be cheaper to just buy the high octane to begin with.
#29
RE: Whats normal
An update. Im sorry to bump an old thread but i felt it needed an updated. First off i only used octane boost when i had no choice to put in cheap ARCO gas. (if you know what ARCO is aka AM/PM). I went to chevron put in 91 octane no octane boost and ran the car. Same issue. I ran that tank out got fuel again at chevron 91 octane no octane boost. Car starting boosting 13-15 not hitting the high ones anymore. Ran that tank out. filled up with 91 from chevron with octane boost, i did check the bottle it is safe for our car ill get the name next time im at the gas station my wife tossed the bottle. She started boosting high again. I think i now understand why shes boosting high. I wont be using any octane boost and i'll make damn sure to keep good fuel in her
#30
