check engine light
Old Feb 22, 2007 | 10:36 PM
steve416's Avatar
steve416
Default check engine light
I just bought a 03 Srt-4 29kmi3days ago and today the check engine light came on, what should I do?
Im new btw, Thanks in advance for the help.
Old Feb 22, 2007 | 10:46 PM
steve416's Avatar
steve416
Default RE: check engine light
the code is P 0440
Old Feb 22, 2007 | 11:43 PM
Plan B's Avatar
Plan B
Check your gas cap. If the seal is bad you will get the above mentioned code I believe......
Old Feb 23, 2007 | 03:46 AM
steve416's Avatar
steve416
the cap seems fine, but I heard that shell 91 gas can do it and I got a tank of it the day i got it( 2days ago) so Im gonna reset my whole thing and see if it goes away.
Old Feb 23, 2007 | 10:12 AM
redevil's Avatar
redevil
Check your gas cap, your purge solenoid and obviously all of the vacuum lines for cracks......hope this helps
Old Feb 23, 2007 | 04:36 PM
NYYDYNASTY's Avatar
NYYDYNASTY
P0440-general Evap System Failure
i wouild bring it back to teh dealership that you bought it from. have them check that out. I'm not sure what woiuld cause that code. The only thing I can suggest is to clear the code and see if it comes back. It might have been a freak code and will never appear again.
Old Feb 23, 2007 | 04:39 PM
PSI Chick's Avatar
PSI Chick
it's usually caused by an improperly sealed gas cap. clear the code, it probably won't come back. if it does, then replace your gas cap.
Old Feb 23, 2007 | 06:04 PM
Plan B's Avatar
Plan B
ORIGINAL: steve416
I rock the Shell 91 (best option in my parts) and I have never thrown this code....
