Maxxfab Exhaust
Old Feb 27, 2007 | 04:06 AM
  #41
PSI Chick's Avatar
PSI Chick
Default RE: Maxxfab Exhaust
the bumpers are exactly the same from 04 to 05, not sure what you're referring to there. if you get a side exit just roll the back bumper.
a cat isn't a big deal. i have emissions testing every year and i pass with no cat. as long as you have a stage ecu it doesn't throw a code and that's all the obd machine cares about. you just need to find a shop that's not going to be retarded and actually look for everything lol.
Old Feb 27, 2007 | 04:15 AM
  #42
WASRT4's Avatar
WASRT4
so what do you do.. just cut it even from the top of the cut outs?
Old Feb 27, 2007 | 04:17 AM
  #43
Dave_04's Avatar
Dave_04
i thought they were dif, i havnt had the car long and just finding out things about them thanks for the correction.
Old Feb 27, 2007 | 04:29 AM
  #44
WASRT4's Avatar
WASRT4
AHH i found it on srtforums.
Old Feb 27, 2007 | 09:03 AM
  #45
redevil's Avatar
redevil
is there much diff between a side exit exhaust and regular exhaust??any advantage?
Old Feb 27, 2007 | 08:23 PM
  #46
Plan B's Avatar
Plan B
I'm installing the S.E.E saturday and I plan on just rolling the bumper until i get some dough to have it molded and re-sprayed. The advantage to the side exit is the exhaust has less pipe to travel through making it more free-flowing. According to the MaxxFab site, you can get more power out of the exhaust because of how free flowing it is. I also like the idea that it is simply different than what you normally see on the road. With the o2 housing and the turbo back side exit exhaust I believe the dyno numbers on the site were showing gains of almost 20hp. Or maybe it was written in the 'Exhaust for Dummies' section on there...
Old Feb 28, 2007 | 01:17 AM
  #47
redevil's Avatar
redevil
damn deff getting that exhaust then.....does maxxfab sell the tips separate?
Old Feb 28, 2007 | 06:06 AM
  #48
Aceburner's Avatar
Aceburner
ORIGINAL: PSI Chick
So if I got a stage 3 and a catless turbo back and code scrubber, I would pass emissions? They do them in Ohio but I never had a car there since I bought mine from base. I don't know how strick it is.
Old Feb 28, 2007 | 07:23 PM
  #49
Plan B's Avatar
Plan B
ORIGINAL: redevil
The exhaust comes with an oval tip, 5inches x 2.5 or 3, or something like that. The tip is welded on and looks pretty nice. Were you wanting a different one or something?
Old Feb 28, 2007 | 07:52 PM
  #50
Aceburner's Avatar
Aceburner
ORIGINAL: Plan B
ORIGINAL: redevil
Well I would have liked to have my own tips on the maxxfab. I wanted to know if they were welded and if the were how hard would be to change them for different ones.
