problems.... please help
Old Feb 28, 2007 | 08:48 AM
noplayen05srt's Avatar
noplayen05srt
Default problems.... please help
ok so i started reading on here and the brotheren srtforums.com at like 5 this after noon and no its 5 in the morning.... i have read a whole lot and an confused and knowledgeable now lol but i still am lost with my situation.... i have a couple codes ...... there was more but i clearded them not thinking before writing them down... one is over boost which is obvious when i drive considering i spike at 2o to 25 and drop to 18 and hold til red line.... what could that be?? all leaks have been fixed so i think maybe my wga??? the next is P0301-CYLINDER #1 MISFIRE i checked the plugs and they were covered in oil.... wtf??? tell me why or how... im lost i cleaned them and what not and it seemed to get worse.... then after a while got worse ... help please!!!!!!!!!!
Old Feb 28, 2007 | 10:19 AM
aiverson's Avatar
aiverson
Default RE: problems.... please help
what are your mods? Do you have a CC? oil sounds like oil blow by, you need a CC. if wastegate stock, it could be stuck shut, if it's not stock, you need to adust it down.
Tony
Old Feb 28, 2007 | 12:18 PM
redevil's Avatar
redevil
i don't think he can hold 18 psi with a stock wga.If you don't have a catch can buy one or make one.What kind of fuel mods you got?
Old Feb 28, 2007 | 01:20 PM
aiverson's Avatar
aiverson
your right I don't think the stock wga will hold 18 psi and that is why I think his gate is stuck either that or his gage is busted, and that is if he still has the stock wga. He is in need of a CC that is for sure.
tony
Old Feb 28, 2007 | 08:17 PM
PSI Chick's Avatar
PSI Chick
severe oil like that on the plugs isn't going to be solved by a catch can. sounds like your valve seals are shot.
and there's no way that you're holding 18psi on the stock turbo with the stock wga. it just doesn't hold that high. plus if you've been doing that for a while that could be contributing to the issue with the valve seals, you're running too lean.....
Old Jul 28, 2007 | 02:44 AM
noplayen05srt
to up date yes it was holding 18 it would spike at 22 then hold 18 everything was stock... valve seals were fine all interals were good.. there was a new guy working on it that supposidly knew what he was doing but i guess didnt he was messing with the boost and somthing got messed up ... then my wastegate went out i i was barying the needle bacl around to the stop and it held boost gage was good worked fine .... unfortunatly i dont have the car anymore i sold it and regret it very much but i made some money off it sold it for 20 grand bought it new for 18,500 as i believe i have posted before... looking at an 05 comemorative edition now though!! #182
Old Jul 29, 2007 | 02:29 PM
srt4quagmire's Avatar
srt4quagmire
wow you sold it for 20g? With oily plugs..... i guess these things are getting wrecked alot for a resale like that to happen.
Old Jul 29, 2007 | 08:03 PM
PSI Chick's Avatar
PSI Chick
not really. there's a suckerborn every minute though.
Old Jul 30, 2007 | 01:05 AM
noplayen05srt
yea i did and to a dealership of all things....or people
Old Jul 30, 2007 | 11:14 AM
Burnnout's Avatar
Burnnout
Unless you bought a new car and they are "saying" they gave you 20g for it by jackin up the new car price, you are full of ****, sorry.
