help...
Old Mar 9, 2007 | 06:12 AM
Kristjan SRT4's Avatar
Kristjan SRT4
Default RE: help...
Sombody told my that if you take your downpipe out, the o2 sensor senses more heat than usual and the car starts hesitating. And get's all ****ed up:s I was thinking about taking the downpipe away and replace it eith a pipe, but some genious told me not to, it would cause alot of problems
Old Mar 9, 2007 | 03:24 PM
PSI Chick's Avatar
PSI Chick
Default RE: help...
how do you plan on taking the dp out? you kinda need that to hook up to the rest of your exhaust
Old Mar 11, 2007 | 01:29 PM
turbosrt's Avatar
turbosrt
Default RE: help...
i just checked the 50 tim and it does have some shaft play not in/out but side to side i am wonderng if thats why i am not getting full boost
and it takes forever to gt to the 15psi if i go wot at herd driving , could be turbo on its last leg?
[/align]
Old Mar 11, 2007 | 02:20 PM
redevil's Avatar
redevil
Default RE: help...
is it burning oil?are you floring it at high or low rpms, if you go from low rpms with a big turbo its gonna take forever to spool.I raced my firends 60 trim last nite, we went from 3rd at 2500, I pulled a whole bunch on him, eventually he caught up and blew past me.Why are you running at 15psi?I would turn up the boost and get the car tuned right
Old Mar 11, 2007 | 04:08 PM
turbosrt's Avatar
turbosrt
Default RE: help...
well the boost is up i should be getting like 22psi but i am only seen 15 dunno could be the wastegate too, i am going to disconnect it to see if i get full boost i got plenty of fuel
[/align]
Old Mar 11, 2007 | 11:48 PM
turbosrt's Avatar
turbosrt
Default RE: help...
disc wastegate and no difference still doing 15 psi of boost, running out of options could be the ecu cutting down on boost?
[/align]
Old Mar 13, 2007 | 12:01 AM
turbosrt's Avatar
turbosrt
Default RE: help...
bump..
[/align]
