QUESTION!! DO ALL THE COLORED HOSES HAVE TO CONECT SOME WHERE?!!
Old Mar 14, 2007 | 01:51 AM
SMTYLEZ's Avatar
SMTYLEZ
Default QUESTION!! DO ALL THE COLORED HOSES HAVE TO CONECT SOME WHERE?!!
ok, you all know how there are colored lines by the intake pipe, red,green, blah blah you know all those colors, we'll do the all have to conect somewhere, i was looking around in the engine bay just to look around for oil leaks or anything, and i see the red one goe's to the hardpipe or "ic pipe", but i was looking and i think theres a light pink and or a light green line weren't conected to anything they where just "hangin around" is the best way to describe it.. i dont think i have any problems with bost leak i used to be at 16 17 psi holding off S1, then i took off the the w.g. and put a forge. didnt like it then i put the stock w.g. back an now i'll be lukky if i hold 15... anything ishould pay any mind to?!
Old Mar 14, 2007 | 06:01 AM
PSI Chick's Avatar
PSI Chick
Default RE: QUESTION!! DO ALL THE COLORED HOSES HAVE TO CONECT SOME WHERE?!!
the pink line should be hooked up to your stock surge valve if you don't have a aftermarket bov. the green line is very important, that one hooks up to the back of the turbo. put it back on lol.
Old Mar 14, 2007 | 11:03 PM
SMTYLEZ's Avatar
SMTYLEZ
the only lines that are not connected are the blue and pink lines, i have the hks bov with the e.d. hardpipe so should the pink line be connected and what about the blue.. the green line is connected to this black rubber thing and that is connected to the turbo i guess ???
Old Mar 15, 2007 | 04:44 AM
PSI Chick's Avatar
PSI Chick
responded to your email.....
Old Mar 15, 2007 | 08:37 PM
silverblacksrt4's Avatar
silverblacksrt4
what about the red line?? it isn't hooked up to anything on my car!
Old Mar 16, 2007 | 03:19 AM
SMTYLEZ's Avatar
SMTYLEZ
red line should be hooked up to your intercooler pipe hard or plastic
Old Mar 16, 2007 | 04:27 AM
PSI Chick's Avatar
PSI Chick
check your spam folder, just got your email that you never received mine. it might be in there....
Old Mar 17, 2007 | 06:05 PM
SMTYLEZ's Avatar
SMTYLEZ
ok the pink was is plug to a rubber cover thing, and i've searched everywhere for where the blue line goes and i can't find anything!? i was looking for over an hour and took my sway bar off and couldnt find anything to plug it into..
