boost cut
Old Mar 17, 2007 | 05:12 AM
rare04's Avatar
rare04
Default boost cut
Alright let see if I can get this right. So I'm heading down the freeway in 5th gear and decide to give it some gas to pass and the turbo starts to cough and sputter and I quess the boost cut outon me. I leave the gas massed down out offrustation and now the damm car spitts and sputters when I get on the gas. I cant even boost pass 10 psi with out the sputtering happening. I have changed the plugs and still nothing.Part throttle is good to 5 psi, and after that nothing but ****. Any Ideas, man I'm @a lost. I have an AGP wgt and a boost controller (MBC), w/ a **** load of bolt ons. What cha think? Thanks
Old Mar 17, 2007 | 10:42 AM
redevil's Avatar
redevil
Default RE: boost cut
i think you need to lower your boost buddy.same thing happens to me when I floor it at low rpms in 4th or 5th.If you take your boost down to 17 maybe 18 then it wont do it, but if you spike 20+ then yeah it'll keep doing it.Stock fuel system sucks but you have to learn to live with it.Good luck
Old Mar 17, 2007 | 07:02 PM
rare04's Avatar
rare04
I have lowered the boost and its a bit better, but now it'll cut out for asec and then back to boosting. But this damm cutin out s--t, what the hell is that about. Whats the sign of a Turbo going out?
Old Mar 17, 2007 | 11:21 PM
redevil's Avatar
redevil
nah i dont think so.are you stepping on it on high gears at low rpms?cause if you are you're still gonna get it.Race fuel helps a lot, it did for me.
Old Mar 18, 2007 | 12:13 AM
rare04's Avatar
rare04
This is in all gears. WOndering if the fuel pumpp is going out or got hurt. Also possibly the fuel pressure regulator if we have have one, if so were's it at? Maybe its taking a ****.
Old Mar 18, 2007 | 02:14 AM
srtratblock's Avatar
srtratblock
Sounds like the mtr. leaning out under boost, if it's poping back through air intake.
Old Mar 18, 2007 | 03:55 AM
Dave_04's Avatar
Dave_04
I'm having the same problem but in the low gears also and mine is stock, first is ok but second and third are like **** any advice for me, sorry to post on your thread but i would hate to have posted the same question. it really sucks cause i just got beat by a GT i have beaten before, and thats not good. help please
Old Mar 18, 2007 | 09:53 AM
redevil's Avatar
redevil
the cheapest way to fix that is buying a fuel pump and a map clamp.....but Im not a big fan of map clamps.I still get boost cuts but in 4th and 5th only if I step on it at low rpms.But running from 1st to 4th I have no problem, also rolling from 2nd.Race fuel helps.I dunno what to say.Boost cuts usually happen when theres is too much boost, like spiking 22 psi.But since you lowered the boost and dave is running stock boost then I'm kinda lost here.Im sure someone more knowledgeable will dig in and give you guys a hand.
Old Mar 18, 2007 | 01:27 PM
littleblackmachine05's Avatar
if ur car isbreaking upafter 5 psi then its ur coil pack. i had the same problem. i knew some people who worked at the dodge dealership n we could not figure out what it was cause it wasnt throwing any codes.i took everything off n broughtmy car back to stock but it was still breaking up. if ur car is cutting out after 17psi then it fuel cut. u have 2 choices, u can get a stage 1 ecu which will eliminate that problem or u can buy a fuel cut defencer and a boost cut defencer. try that then post back
Old Mar 18, 2007 | 03:22 PM
monstab757's Avatar
monstab757
rare04, i take it by your screen name that you realize how rare your yellow 04 really is. thats pretty cool to meet someone who actually got there hands on one of these. i had a buddy at work who looked for one for a while but finally gave up.
