front end shimey
Old Sep 1, 2004 | 03:08 AM
hair's Avatar
hair
Default front end shimey
recently went 12.47@114.9 w/stock turbo and all forward motionparts. stg1 w/wastegate accuator full 3 in. exhst. drg. radials ect. thats it! on the way home last time i noticed the front end shimeying under acc. in first gear mostly did i break amotor mount?p.s.forward motion rules!
Old Sep 1, 2004 | 03:13 AM
PSI Chick's Avatar
PSI Chick
Default RE: front end shimey
probably did...the stock ones are pretty bad and they break very easily. i would suggest upgrading to the psi-fi dogbones, they're a very good mount, and now are going to be made of upgraded materials...
Old Sep 6, 2004 | 09:02 AM
71RoadRunner's Avatar
71RoadRunner
Don't get your motor mounts confused with the torque struts. When people refer to your motor mounts they are actually talking about the torque struts, when you get motor mount inserts they are actually going into the torque struts and not the actual motor mounts.
